It is currently Thu Jul 19, 2018 5:02 am
Reply to topic  [ 7 posts ]
 Gaz coilovers £482
 Post subject: Gaz coilovers £482
PostPosted: Wed Mar 10, 2010 3:24 pm
Thu Dec 28, 2006 10:46 pm
We have our own custom GAZ coilovers for sale at £482.
These are designed to fit any bubble 200, 25 or ZR.
They are based on the road kit, but use the larger (stronger) rod from the GAZ Gold coilovers inside the road body (allowing for the narrower spring/wider wheels).
They are also designed to allow the car to be lowered more than the standard kit if need be.
Each kit is ordered specifically to your vehicle/intended usage. (engine weight, wheel size, track or road useage etc).
We can also offer the standard kit at the same price.
Any questions feel free to ask.
Adrian
K series headgasket repair from £270
ZR T16 turbo conversion from £870
ZS 180 Timing belts, water pump and thermostat housing from £535
MOT and service £80
www.AMWmotorsport.co.uk
 Post subject: Re: Gaz coilovers £482
PostPosted: Wed Mar 10, 2010 7:27 pm
Thu Jul 03, 2003 12:15 am
washington
hey fella, one of my avo's has started leaking on the bubble track car and tbh the spring weights are wrong combined with the body's being rusty etc so am thinking of ditching them, car is used for 90% track usage and is a T16 bubble running on 16" wheels..., what would your kit come in at and what sort of poundage would you recomend???, also worth noting is the car has been completely weight reduced, runs no interior, to give a idea of the weight i have even stripped the wireing harness and removed any unused wiring....
cheers, simon
Home grown mk3 turbo....
My Vouch thread CLICK HERE
PostPosted: Thu Mar 11, 2010 12:49 pm
For track use, you'd be after around 450 on the front and 500 on the rear. But beware, this would create an awfully harsh ride for the road, especially on the smaller, unsmooth B roads.
MOT and service £80
PostPosted: Thu Jul 01, 2010 5:28 pm
Tue Feb 20, 2007 2:27 pm
Dunfermline
do you keep either of the above mentioned coilies in stock?
are you able to supply standard strut top mounts to go with them?
PostPosted: Fri Sep 03, 2010 8:12 am
Thu Oct 22, 2009 9:15 pm
hi ive also got set of avo and they have started to leak at rear
im asking what poundage would u recomment for zr, with t16 conversion, full interior still, sound system in boot consisiting of false floors ect so fait bit of weight (was on zr straights 17" now on set of wolfrace 17's)
im after mainly road use so of course wouldnt be after massive poundage??? but i dnt mind the harsh ride tho in fact it makes it even more enjoyable
PostPosted: Mon Sep 13, 2010 10:07 pm
bump?
PostPosted: Mon Jan 17, 2011 6:58 pm
Mon Dec 27, 2004 12:05 am
West Mids
Can you supply a GAZ kit for the 220 coupe turbo at all? Id be looking at an 80/20% road/track use, and i don't want the car to become too harsh, but would like it to sit about 25-30mm lower and perfectly level all round.
