It is currently Sun May 20, 2018 4:50 pm
Reply to topic  [ 13 posts ]
 Geometry check points R25/MGZR body
 Post subject: Geometry check points R25/MGZR body
PostPosted: Thu Mar 21, 2013 2:01 pm
Mon Jan 30, 2012 6:48 pm
Moscow, Russia
Need geometry check points for R25/MGZR body. who can help?
2002 MG ZR 160 N17942
Friendly forum "Union Jack crazy wheels" http://www.rovermg.ru/forums
 Post subject: Re: Geometry check points R25/MGZR body
PostPosted: Thu Mar 21, 2013 7:51 pm
Moscow, Russia
it mean that i need such schema:
PostPosted: Fri Mar 22, 2013 5:55 am
Moscow, Russia
anyone... please, help
PostPosted: Sat Mar 23, 2013 1:22 am
Mon Mar 12, 2007 5:48 pm
Oxfordshire
Its in RAVE, but spread over several pages for the various views areas, under panel repairs in the workshop manual section.
RAVE wrote:
The following dimensional information is shown so as to assist the technician in the diagnosis and repair of body panels. The information is shown in two different ways. There are X,Y,Z dimensions and actual point to point dimensions.
The X,Y,Z dimensions are the measuring planes used within Rover Group for the measurement of body panels. The whole bodyshell is within a parallel grid system.
The X plane is an imaginary vertical plane starting at the front of the vehicle. It is parallel and at right angles to the centre line of the vehicle and measures distances along the length of the vehicle.
The Y plane is an imaginary plane through the centre of the vehicle. All Y dimensions start from this plane. As a rule, body dimensions are symmetrical about the centre line.
The Z plane is set at a fixed distance parallel to the underside of the vehicle. All Z dimensions start from this plane.
The point to point measurements are actual distances between two points. These points can be holes or intersection points. Where holes are taken, the point of measurement is always from the hole centre.
All measurements shown are in millimetres.
>>>Spec thread<<<
PostPosted: Sat Mar 23, 2013 9:55 am
Moscow, Russia
stefaclese wrote:
Its in RAVE
many thanks!!! :thumbup:
can you send me this .pdf file?
PostPosted: Sat Mar 23, 2013 8:39 pm
Oxfordshire
No because its a huge database built up out of various pdf's, its nearly 800MB in size. You'll have to see if you can download it anywhere, I think I got mine back when copies were floating around on various forums several years ago.
>>>Spec thread<<<
PostPosted: Mon Mar 25, 2013 6:01 am
Moscow, Russia
can you post a pic with actual point to point dimensions ?? thanx :)
PostPosted: Fri Apr 05, 2013 8:50 am
Moscow, Russia
up :help:
PostPosted: Fri Apr 05, 2013 5:55 pm
Moscow, Russia
£5 at paypal for first, who post here a picture with actual point to point dimensions for Rover 25|MGZR bonnet
PostPosted: Fri Apr 05, 2013 7:25 pm
Oxfordshire
There aren't any for that particular area, it's just the x, y and z dimensions I'm afraid.
>>>Spec thread<<<
PostPosted: Fri Apr 05, 2013 9:07 pm
Moscow, Russia
you sure??? it's impossible to get pic as in my 2nd message??? Rover can be restored only in special repair company with special repair tech?
but why RAVE have info about particular area of Rover 75, and haven't about Rover 200|25 ??????
 Post subject: U NJ
PostPosted: Sat Apr 06, 2013 4:53 pm
Oxfordshire
Like I keep saying, those are the only dimensions for that area. The point to point dimensions are only for side views of the whole car and stuff to do with the underside and suspension. The only point to point dimension for the engine bay given is between the strut top centres.
If you just need to know the distances between holes side-to-side you double the number for the y value. Using the view below you should be able to work out the position of the x axis in relation to the car. Or deduct the smaller x value from the larger one when trying to work out the distance between two points in the x direction.
>>>Spec thread<<<
PostPosted: Sun Apr 07, 2013 4:30 pm
Moscow, Russia
thanks mate, pm your paypal for payment.
