It is currently Fri May 25, 2018 3:30 pm
Reply to topic  [ 27 posts ]
 Basic "how to" Snow Foam Pre Wash
 Post subject: Basic "how to" Snow Foam Pre Wash
PostPosted: Tue Jun 17, 2014 9:00 pm
Newbie to snow foam process so thought i would document my process and results
What is snow foam?
Snow foam is a pre-wash foam, sprayed onto the car to dissolve and remove as much dirt as possible before washing by hand.
What do i need?
Water supply
Pressure washer
Snow foam lance with suitable connections
Snow foam solution of your desire
My choice of starter kit
Autobrite Direct Magifoam purple
Autobrite Direct Snow Foam Lance
Each manufactures foam will differ for dilution and also application, best just to get stuck in and see what works for you
To start with I went with Autobrite’s instructions (if you have the Autobrite snow foam lance) to see where that got me. (Bare in mind that the foam will vary depending on the brand of snow foam concentrate you use)
Autobrite’s Lance instructions are as follows…
“To use simply apply 50-200ml (depending on pressure washer) of either Autobrite Super Snow Foam or Magifoam into the 1 litre container bottle and fill up with warm or cold water. Each 1 litre bottle when full will foam approx 2 cars. You are now ready to use the Autobrite Snow Foam Lance by switching on your machine and altering the black adjuster on top of the lance for your desired foam. The adjustments are: towards the + on the knob gives you more water - less foam and towards the - on the knob gives you less water and more foam for a stronger mix.”
Magifoam instructions:
Magifoam has been primarily formulated to be used in a foam lance, with a dilution rate of 100:1 it is also very economical, this equates to roughly 1-2" in the bottom of a 1l bottle in a foam lance when using with a domestic pressure washer. To use simply rinse car surface first, then spray the car with a liberal layer of foam and allow to dwell for at least 10 minutes, after this time simply rinse the foam off and watch the dirt rinse away too. The longer this product dwells the deeper it penetrates into the dirt and more of the dirt will then be removed
K2
I went with car dry before application, seems to a lot of personal views to whether you wet car before foam or dry
Result will differ on the following
1. level of last stage product protection ie wax or sealant
2. level of dirt on the car
Cannot be seen here but, front of car was heavily affected by motorway/summer flies and bugs
Following is a short but hopefully purposeful insight into how it went on. ( i am trying to stay out of shot, hence strange angle and application technique)
As you see, water to foam mix can be adjusted very easily for preference but the control knob, and also spray patter too.
Car covered, and starting to dwell nicely
sticking well i feel, approx 6-7 mins after application
Now after the prescribed 10 mins suggested dwelling period
Final stages
Now wash out your snow foam lance and store and switch your pressure washer lance back to your preference
Close up of front, really impressed at how it dissolved the bugs and flies
Side shot, LSP doing well
Couple of closing "money shots"
Thanks for looking and hope there isnt too much wrong, like i say, i am not a professional, just a keen DIYer
 Post subject: Re: Basic "how to" Snow Foam Pre Wash
PostPosted: Tue Jun 17, 2014 9:09 pm
Good starter guide Greg. :thumbup:
My one recommendation as a complete newb to detailing is steer clear of Demon Shine foam, it doesn't have the strength to dissolve a wet paper bag let alone traffic grime.
PostPosted: Tue Jun 17, 2014 9:16 pm
Wed Oct 17, 2012 8:47 am
Goudhurst, Kent
Nice one Greg. Always wondered what the hell snow foam was!
Stu
See my 1.8 k-turbo project: http://www.rovertech.net/forum/viewtopic.php?f=10&t=147320
PostPosted: Tue Jun 17, 2014 9:17 pm
Thanks pete
yeah will be staying away from the demon
PostPosted: Tue Jun 17, 2014 9:18 pm
Really pleased at how its turned out
PostPosted: Tue Jun 17, 2014 9:22 pm
Sun Mar 27, 2011 9:02 pm
great post. looks a good bit of kit you have there.
click link below
http://i.imgur.com/GLKdJ.jpg
PostPosted: Tue Jun 17, 2014 9:57 pm
Thu Apr 12, 2007 5:40 pm
I need to get me some of this. 8)
'96 Rover 600Ti
'99 Rover 820 Vitesse
Click Here ->MY 600Ti
Click Here ->Rover 820 Vitesse
PostPosted: Tue Jun 17, 2014 10:45 pm
PostPosted: Mon Jun 23, 2014 11:40 am
can consideration be given to making this a sticky?
would like to know admins thoughts on this either way
feel free to pm me
thanks
PostPosted: Mon Jun 23, 2014 12:22 pm
So do you juat pressure wash the snow foam off or hand wash it off?
PostPosted: Mon Jun 23, 2014 12:27 pm
rinse/pressure wash off
then move onto the two bucket washing method then proper restore/rejuvenating/maintenance processes can take place then protection
full circle and back to a fully well protected and pre prepped car once snow foam should need very very minimal hand contact during a manual washing stage
this would be the best practice and "ideal" way to keep swirling and scratches being induced quicker than they need be
in terms of maintenance, snoam foam, rinse, 2bucket shampoo/wash then rinse again and dry
PostPosted: Mon Jun 23, 2014 12:38 pm
:thumbup: i actually gotvmy brm washed yesterday but its screaming out for a da polish.... al have to borrow my brothers.
PostPosted: Mon Jun 23, 2014 12:40 pm
look forward to see your progess
PostPosted: Fri Jun 27, 2014 7:12 pm
Fri Feb 21, 2003 1:53 am
Wombourne, Staffordshire
After seeing this I decided to get myself the same lance however I have got the citrus snowfoam instead. Followed the instructions on the bottle which said to pre wet then foam. Having done this I would recommend the dry car method as after 5 mins pretty much all the foam has run off and the car actually started to dry.
Good stuff though.
220 GTI TURBO - gone but never forgotten. :(
New Project Arrived :)
PostPosted: Sat Jun 28, 2014 3:39 pm
Mon Dec 27, 2004 11:17 pm
At the bridge, with Horatius.
Good, easy to follow instructions :D but..
who painted the car ? Mr Tango'd ?
Time to get the 1200 grit paper out methinks.
Stella now gone, Ruby is my baby now.
For your photography needs, try
http://www.freelancephotographic.net
PostPosted: Sat Jun 28, 2014 4:21 pm
Yeah its bad isnt it
Being addressed monday
PostPosted: Sat Jun 28, 2014 4:56 pm
I'd go for a bit of wet sanding with 2000 grit, glassy finish coming right up.
PostPosted: Sat Jun 28, 2014 5:00 pm
Be more than that :wink:
PostPosted: Sat Jun 28, 2014 5:34 pm
Kerbstone ? :scared:
PostPosted: Sun Jun 29, 2014 2:02 pm
A member of the 800 forum details his cars using wet 1200 paper, he gets two sheets and rubs them together to get some of the grittiness off and goes to work on the paint. It takes a while but his results are outstanding.
I don't think he'd mind me showing you the results
PostPosted: Sun Jun 29, 2014 3:44 pm
Seriously impressive results and workmanship
Serious skill there
Wet sanding is a great skill to have ( which i dont ha ha)
PostPosted: Fri Sep 05, 2014 4:50 pm
Wed Oct 23, 2013 2:43 pm
Ipswich
Surely wet sanding creates spirals on the paintwork, I can't get my head around this, but the photos do proove me wrong so....
Top thread by the way. :thumbup:
PostPosted: Fri Sep 05, 2014 6:22 pm
wet sanding removes the peaks in the top coat. You then have compounds to remove the grit marks (swirls and streaks)
'96 Rover 600Ti
PostPosted: Sun Sep 07, 2014 11:23 am
Fri Mar 03, 2006 3:02 am
North London
As mentioned above you use the wet sanding to remove the orange peel effect and then you use a polisher to make it like glass which removes the scratches left from the wet sanding.
1995 Rover 220 Turbo Coupe Tahiti Blue FDH (current)
1993 Rover 220 Turbo Coupe Jet Black (current)
1991 Rover 214SLi Silver/Champagne (current)
PostPosted: Mon Oct 20, 2014 3:05 pm
Thu Aug 10, 2006 5:07 pm
I think the foam lances are a bit of a waste of money tbh.
I used same product as shown at the top and On a very dirty car it will get rid of some but not most dirt.
You still have to wash the car.
On a well maintained car that's regularly washed and polished there's not much point and you may as well just wash it.
That's my opinion although it is fun I suppose and really shows the neighbours just how anal you are about cleaning your car.
The most important thing to get shine when waxing/polishing a car....clean cloths.
That 1200 grit wet sanding thing looks interesting though :thumbup:
PostPosted: Mon Oct 20, 2014 3:33 pm
1200 wet sanding does give a glass like finish, but does it ever require some patience and dedication, I've used it to blend clear coat, it worked perfectly, but doing a whole car, pfft, :lol:
PostPosted: Tue Oct 21, 2014 9:29 am
Pete I once sprayed my bonnet and don't have a DA so I had to cut the paint by hand lol
It took 3 hours just to do a 1/2' square...my arms hurt a bit after the week it took me to do the whole thing :D
Maybe I shoulda used the 1200 grit method instead of cutting compound.
