It is currently Fri Jun 22, 2018 7:34 pm
 EDC15M L series diesel ECU
 Post subject: EDC15M L series diesel ECU
PostPosted: Mon Oct 06, 2014 2:33 pm
Please post success or failure (and which vehicle) with EDC15M ECUs here
Low cost diagnostic tool for Rover, MG & Landrover cars http://pscan.uk
 Post subject: Re: EDC15M L series diesel ECU
PostPosted: Tue Oct 07, 2014 10:40 am
Sat Dec 10, 2011 1:37 am
Working on our 53 plate ZR TD. Brought up 6 codes that cheap OBD readers didn't find, 2 of which came back after erasing so I've got some work to do!
PostPosted: Sun Aug 06, 2017 4:35 pm
Sun Aug 06, 2017 4:26 pm
Hello,
Works on Rover 25 2.0 TD 2001.
Show and erase those errors :
P1402 EGR Metering Orifice Restricted
P0601 Internal Control Module Memory Check Sum Error
P1215 Pedal Position Sensor C Circuit Low Input
P0215 Engine Shutoff Solenoid Malfunction
P1222 Traction Control Output Circuit Malfunction
Only the first two errors have came back. :whistle: :whistle:
Show all live datas as the picture in the pscan site shows. :thumbup: :thumbup:
Question : My "airflow" is 750mg/s and in the pscan.eu site the rover 45 2.0td works with more than 2000mg/s for the same engine speed. How to know which value is right ? Does it exist a list of reference values ?
regards,
al :drive: :drive:
PostPosted: Mon Aug 07, 2017 7:54 pm
If you look at the live data shown on the website:-
Engine speed=0 RPM
so the airflow figure is clearly not real.
We don't have access to a real running EDC15M car, only an ECU on the bench so you will have to see if other people can compare their numbers with yours.
