It is currently Mon May 21, 2018 4:28 am
Reply to topic  [ 55 posts ]  Go to page 1, 2  Next
 software to try if your pscan.eu interface does not work
 Post subject: software to try if your pscan.eu interface does not work
PostPosted: Wed Sep 02, 2015 10:47 pm
I have only written this for Windows so far...
If you cannot get your interface to work, please download this software
http://www.pscan.eu/download/win32/pscantest03.exe
plug your interface into your laptop, and run it, then click on start.
Then please copy the text that it produces and paste it into a reply to this thread.
I am monitoring this thread so I should get an email straight away and can look to see what the problem is.
 Post subject: Re: software to try if your pscan.eu interface does not work
PostPosted: Thu Sep 03, 2015 2:38 pm
Sun Jun 12, 2005 9:45 pm
gloucestershire
Hi, Just got my PSCAN unit and get the following message.
Starting
1 interfaces found
AH02ZVJD
status=60A0
interface not powered
Finished
This is the first time install and i simply have the unit connected to my pc and the pc connected to the internet. Should i be connected to the car diagnostic port as well?
Nigel
PostPosted: Thu Sep 03, 2015 3:18 pm
Most of the pscan.eu interface is powered by the car, not the PC.
In fact only one chip in the interface is powered by the PC.
The message you are seeing is 100% consistent with the fact that it isn't plugged into the car.
It also means that the FTDI driver has correctly installed which is good news.
When you plug the interface into your car you will see a green flashing light on the interface. This means that it has powered up correctly and you can use it.
PostPosted: Thu Sep 03, 2015 5:01 pm
gloucestershire
Thx for prompt reply. Just connected it to my MGF VVC and all seems fine. Now to start playing around with it on the good car and then find out why my sons's VVC has high emissions.
Nigel
PostPosted: Thu Sep 03, 2015 5:08 pm
If the test software says this "could not access libftd2xx" then it means that the FTDI driver is not installed.
The solution is to download this:-
http://www.ftdichip.com/Drivers/CDM/CDM%20v2.12.06%20WHQL%20Certified.exe
and run it
PostPosted: Sun Sep 20, 2015 8:00 pm
Thu Oct 30, 2014 8:02 pm
This is what comes up for me
"Starting
Windows version:1DB10106=Windows 7 or Server 2008R2
Cannot load D2XX library
Download driver from http://www.ftdichip.com/Drivers/CDM/CDM ... tified.exe
Finished"
When I try and download the driver a pop up comes up saying "the requested operation requires elevation"
Does anyone know how to resolve this?
PostPosted: Mon Sep 21, 2015 9:36 am
Because that exe file is a driver installer it requires administrative privileges to run.
Download the file and then locate it on your harddrive.
Right click on the file and select "Run as administrator".
PostPosted: Mon Sep 21, 2015 8:05 pm
Thanks Phil all working now :D keep up the good work mate!!!!!
PostPosted: Thu Sep 24, 2015 1:29 pm
Mon Sep 21, 2015 2:54 pm
Hi... Got a startup problem...
Starting
D2XX version:00030207
0 interfaces found
Finished
PostPosted: Thu Sep 24, 2015 2:28 pm
Is your interface connected with a USB cable to the Pc? You might have to plug it in and then wait for 20 seconds or so before clicking on Start.
PostPosted: Thu Sep 24, 2015 3:04 pm
Yes, and "the blip" come when dis- and connecting. Wonder should there be light in the diode when connected? ore first when car is also connected?
PostPosted: Thu Sep 24, 2015 3:18 pm
Most of the electronics are powered by the car. You need to plug into the car and see a flashing green light before you can go any further.
PostPosted: Fri Sep 25, 2015 12:42 pm
Starting
0 interfaces found
Finished
Now with power and diag-plug in/from car
PostPosted: Fri Sep 25, 2015 12:47 pm
are you running pscan diagnostic software and the test software at the same time?
If you are running two software at the same time they will fight each other
is the green light flashing on the interface?
PostPosted: Fri Sep 25, 2015 12:57 pm
it tell to use pscan loader, to those com port but just "counting" and nothing to those i "the box" Yes, green light is flashing
PostPosted: Fri Sep 25, 2015 1:19 pm
does it look like this?
is there text in the box below "Select port here"?
is there also a button saying Next?
PostPosted: Fri Sep 25, 2015 1:21 pm
Exactly that Picture, no text, no next-button
PostPosted: Fri Sep 25, 2015 1:41 pm
Please can you verify that the USB port on the PC is working for other devices (such as a memory stick).
Please can you download this installer
for Windows 7,8,10
for XP and Vista
http://www.ftdichip.com/Drivers/CDM/CDM%20v2.10.00%20WHQL%20Certified.exe
and re-install it.
To install it please right click on the file and select "Run as administrator"
Then reboot your PC and try again.
PostPosted: Fri Sep 25, 2015 3:04 pm
Some more things to try please.
Open your device manager and then expand "universal serial bus controllers"
it should look like this
When you plug in the pscan.eu interface the "USB Serial Converter" should appear, and when you unplug it it should disappear.
Next.
Right click on USB Serial Converter and select
Properties
In the new windows select the Driver Tab end then Driver Details.
It should look like this
This is the information that you should be able to see for each file (mine is 64 bit)
c:\Windows\system32\drivers\ftdibus.sys
Provider FTDI Ltd
File version 2.12.06.3
c:\Windows\system32\ftbusui.dll
Provider FTDI Ltd
File version 1.3.0.1
c:\Windows\system32\ftd2xx.dll
Provider FTDI Ltd
File version 3.02.10
c:\Windows\system32\FTLang.dll
Provider FTDI Ltd
File version 1.5.2.1
c:\Windows\syswow64\ftd2xx.dll
Provider FTDI Ltd
PostPosted: Fri Sep 25, 2015 3:12 pm
if you see an arrow in the device manager like this
This means that the device is disabled.
To fix this you must right click and select "Enable"
PostPosted: Mon Sep 28, 2015 4:23 pm
Hi Again, I did this
and re-install it.
USB-Port ok, my internet is a usb-device.
Then Downloaded from that link, re-install and so on... And now its talking Mems1.6 with a Caterham :thumbup:
Super dooper job, tanks Philip
PostPosted: Tue Dec 29, 2015 8:40 pm
This is what you should see running Windows 7, 8, 8.1 or 10
Code:
Starting
D2XX version:00030210
1 interfaces found
A602FNGU
  status=000060A0
  driver=00021206
Finished
if your D2XX version is less than 00030210 then this will possibly cause a problem.
The default Windows 10 driver (if you just plug in without installing the driver that we recommend) appears to be 00030207 at the moment.
PostPosted: Sat Feb 20, 2016 9:56 am
Fri Feb 19, 2016 10:05 pm
Starting
Finished
PostPosted: Sat Feb 20, 2016 12:54 pm
binraider wrote:
Starting
Finished
Your FTDI driver is not installed.
1. Download this file http://www.ftdichip.com/Drivers/CDM/CDM21214_Setup.exe
2. Open file explorer and find the file.
3. Right click on the file and select "Run as administrator" like this:-
4. Follow the instructions that the installer give you.
PostPosted: Sat Feb 20, 2016 2:13 pm
Hi There, I did that but it has installed under "Other Devices > FT232R USB UART". Pscantest is giving the same error message
PostPosted: Sat Feb 20, 2016 2:34 pm
sorted now - i went into Device Manage, uninstalled the entry that i described, then ran "scan for ..." and after 3 minutes or so it was installed properly
PostPosted: Sat Feb 20, 2016 7:26 pm
Thank you for feeding back your solution.
PostPosted: Wed May 25, 2016 5:18 pm
Mon Jun 16, 2014 10:52 pm
Had no problem with software at all until today, start software, all appears as should comes up Ok 0414 then comes up with Use pscanloader????
tried software for check have this.....
Starting
Windows version:23F00206=Windows 8, 8.1, 10 or higher
D2XX version:00030211
1 interfaces found
AH035WW5
status=000062B0
interface powered
driver=00021216
Finished
car not starting at moment :(
PostPosted: Wed May 25, 2016 7:19 pm
there is something funny going on at the moment, I wonder if Microsoft have pushed an update to Windows 10 which is causing this.
For the time being it seems to work if you disconnect from the internet before running the software
PostPosted: Wed May 25, 2016 7:22 pm
My other laptop (which the battery was flat at the time) running Windows 10 but hasn't been turned on for a while worked fine once I'd charged the battery and used that.
Interestingly when I tried to run the software to begin with (on laptop which it won't work on) the software kept saying no internet connection and wouldn't do anything until I tethered my phone to it...then it still wouldn't work :(
PostPosted: Wed May 25, 2016 7:38 pm
okay on my Windows 10 laptop I am now seeing a process called "antimalware service executable" which maxes out the CPU for a few seconds each time that pscanloader is run.
This is something new and is probably what is causing the problem.
PostPosted: Wed May 25, 2016 8:12 pm
Saw the same on mine, although on mine it was maxing out for longer......which was worrying as I've an i7 processor :(
PostPosted: Wed May 25, 2016 8:24 pm
this is easily fixed
start menu -> settings -> update and security -> Windows Defender
Exclusions -> add an exclusion
+ Exclude a folder
Select the folder in which you have put pscanloader.exe and click "Exclude this folder"
PostPosted: Wed May 25, 2016 9:27 pm
Nice one, works ok now....will just have to remember this when my other laptop updates :)
PostPosted: Sat Jul 02, 2016 2:48 pm
Sat Jul 02, 2016 2:47 pm
also having "antimalware service executable" high usage problem
