It is currently Sun May 27, 2018 12:42 am
Reply to topic  [ 8 posts ]
 Sykes ACR4 or pscan?
 Post subject: Sykes ACR4 or pscan?
PostPosted: Wed Aug 16, 2017 4:29 pm
Wed Aug 16, 2017 4:18 pm
Hello,
I have a Rover Mini mpi (MEMS 2J) I'm thinking of buying a SP ACR4 with a Rover V3 pod but I came across the pscan what are the advantages/disadvantages of this system compared to the ACR4? Is there a comparision list?
 Post subject: Re: Sykes ACR4 or pscan?
PostPosted: Fri Aug 18, 2017 8:51 am
Anyone?
PostPosted: Fri Aug 18, 2017 9:11 am
Mon Mar 15, 2004 9:59 pm
I don't know much about the Sykes offering so can't compare easily.
Is the Sykes a stand alone product, the Pscan needs a laptop.
You can get different modules for the Sykes but the Pscan will only do MG, Rover, Freelander and Mini.
How much is the Sykes?
How easy is it to use?
Will it do other circuits such as ABS, SRS and alarm?
Can it give live data?
Personally I am very happy with the pscan and would recommend it to everyone.
Engine bungled by Zippy, you know, George's Rainbow Smart Mate.
Details at http://www.talkingcars.me.uk
PostPosted: Fri Aug 18, 2017 9:18 am
http://www.ebay.co.uk/itm/Sykes-Pickava ... SwrhBZHWY5
This is the sykes ACR4
PostPosted: Fri Aug 18, 2017 12:54 pm
pscan is cheaper, and doesn't suffer from the limitation of a four line screen. You can view all of the live data parameters at once with pscan. It's also a brand new product with a warranty and technical support.
On the other hand the ACR4 doesn't need a laptop to go with it and so is a bit more portable. Note that you don't need expensive laptop for pscan. A £20 junk one running Linux or Windows XP will do, or you could build a something with a Raspberry Pi. I have also tested it on an old Asus EEEPC (running Debian) which is small and solid state and so can take a knock, and a 12V charger is cheap for these.
ACR4 has the ability to activate outputs that pscan does not yet have.
On the other hand pscan is still in development and will eventually have all of the ACR4 features and more. For example so many customers have asked us for live data logging that we are definitely going to do this at some point.
We try to be as transparent as possible concerning what pscan does and does not do. For a MEMS2J Mini the features that you would get are described on these three pages:-
http://www.pscan.eu/features/mems2j.html
http://www.pscan.eu/features/rc5ec5.html
http://www.pscan.eu/features/5as.html
It isn't so easy to figure out what an ACR4 can or can't do.
PostPosted: Fri Aug 18, 2017 5:39 pm
Thank you both for the replies and the links, it sounds very interesting also like the idea of cheaper, support and continued development. The ACR4 allows adjustment of the stepper motor can the pscan do this?
PostPosted: Sat Aug 19, 2017 3:51 pm
Not at the moment, no.
My understanding is that you can recalibrate it without any diagnostic tool at all.
If it is closed right down and the idle speed is still high then you have an air leak or warped throttle body, and no diagnostic tool can fix that.
PostPosted: Mon Sep 04, 2017 11:19 pm
As per Phil, this doesn't need a machine, search for TPS reset.
