It is currently Tue May 22, 2018 7:20 am
 I need your help Rover Mini MPI
 Post subject: I need your help Rover Mini MPI
PostPosted: Thu Nov 16, 2017 9:41 pm
Thu Nov 16, 2017 3:19 pm
Hi, sorry for my bad english. I have a Rover Mini MPI 1998 and I need one of you to confirm some things.
if you can pair the 5AS of my car with a ECU that buys on ebay. (this is very important for me)
if you can program new key fob. (I need at least two)
if it reads correctly in live diagnostic data. (without errors with update 041A)
Thank you very much for your help, my ACR4 broke down and now I can not pair the new ECU.
 Post subject: Re: I need your help Rover Mini MPI
PostPosted: Sun Nov 19, 2017 9:05 am
Sun May 22, 2016 7:16 pm
Yes, you can replace the ECU and use pscan to learn your 5AS to the ECU.
Also programming a new key fob works fine.
Live data is running, testet with a Rover MINI MPI 2000.
Sent you a short videoclip by PM
- Christian
PostPosted: Sun Nov 19, 2017 10:54 am
You can only match the MEMS2J to the 5AS if the 5AS is unimmobilised.
Therefore if you have no working fobs then you must log into the 5AS first and code in your key fobs.
Once this is complete, unlock the car using a fob, log into the MEMS2J and use the "Learn EMS code" feature to match the MEMS2J to the 5AS.
PostPosted: Sun Nov 19, 2017 5:14 pm
Thats a good point!
I assumed he has at least one fob working.
Gesendet von iPhone mit Tapatalk Pro
PostPosted: Sun Nov 19, 2017 5:48 pm
Technically you could use the EKA with the door key instead.
PostPosted: Sun Nov 19, 2017 10:24 pm
Thank you very much to both of you, I now place the order for my future PSCAN, it's perfect for me :D :D :D
Best regards
