It is currently Sat Jun 23, 2018 9:30 am
Reply to topic  [ 16 posts ]
 Short 220 driveshaft
 Post subject: Short 220 driveshaft
PostPosted: Fri Jun 08, 2018 8:36 pm
As above
I cannot locate my short driveshaft
Anyone have a spare? :thumbup:
Online
 Post subject: Re: Short 220 driveshaft
PostPosted: Sat Jun 09, 2018 8:56 pm
bump
Online
PostPosted: Sun Jun 10, 2018 6:25 am
I have one but would be £80, I kept one for the very same reason you are having problems now.
PostPosted: Sun Jun 10, 2018 8:27 am
Ouch
I can’t find mine
And I believe I pulled the shaft out of the gearbox end cv so ended up with the wheel end which was knackered (I have new cv to fit and the shaft, I don’t know if I can fix it if I find it
What’s your thoughts
Online
PostPosted: Mon Jun 11, 2018 4:04 pm
£104 plus vat for recon of original shaft
Just had an email off a company I messaged
Online
PostPosted: Wed Jun 13, 2018 4:59 pm
Sat Feb 22, 2003 10:56 pm
Saath
do you need the whole thing?
i have one buts its missing the inner cv.
Paul
White ZR Turbo - gone - but new one on its way...
PostPosted: Wed Jun 13, 2018 7:33 pm
I really just need this bit.
Where your inner cv was will be this
Its simply held on with a small circlip and a rubber mallet knocks it off
Online
PostPosted: Wed Jun 13, 2018 7:42 pm
Sat Mar 05, 2011 1:01 am
leeds
I may have one but had a clear out the other month and I'm sure I chucked all my driveshafts out but may be wrong.
I'm back to work on Saturday so I'll check then if you still havnt got one
Cheers everyone
I have a later shaft en route but it may not be the right tripod :lol:
In for a penny and all that
Online
PostPosted: Wed Jun 13, 2018 10:23 pm
Saath
I may be able to find one, may take some effort tho.
What’s it worth to you?
Paul
PostPosted: Wed Jun 13, 2018 10:28 pm
2 pints of beer and some peanuts?
Online
PostPosted: Wed Jun 13, 2018 10:30 pm
Jn
PostPosted: Thu Jun 14, 2018 8:58 am
Sat Aug 25, 2012 10:58 am
leicster
on the boost bus i run custom shafts now.. but i used to run a renault scenic diesel short shaft the tripod end fits the rover gearbox cup but im not sure about the spline in the middle perhaps use one them to recon yours
PostPosted: Thu Jun 14, 2018 3:47 pm
Thanks for that mate
Online
PostPosted: Fri Jun 15, 2018 1:29 pm
Saath
Pm me mate with your messenger.
I have located the end of the shaft.
Paul
PostPosted: Fri Jun 15, 2018 4:01 pm
