It is currently Sun Jun 17, 2018 10:46 pm
Reply to topic  [ 7 posts ]
 Rear calipers
 Post subject: Rear calipers
PostPosted: Wed May 02, 2018 7:24 pm
As above
Rover
 Post subject: Re: Rear calipers
PostPosted: Wed May 02, 2018 7:40 pm
just buy new, they're like £40ea
PostPosted: Wed May 02, 2018 7:49 pm
where?
ideally want zs 180 again, but not fussed tbh
PostPosted: Wed May 02, 2018 8:09 pm
any motorfactors
PostPosted: Thu May 03, 2018 2:37 am
I think they may be in the sale section on rimmers.
Drew
PostPosted: Thu May 03, 2018 5:32 am
Appears to be front calipers for sale currently and not the ZS180 spec type either.
https://rimmerbros.com/Item--i-GRID003117
Only one side of the ZS180 rear caliper seems to be available.
https://rimmerbros.com/Item--i-GRID003121
ZS180/ZR160 rear calipers, new, are more than twice the price than the standard caliper used across the range. Keen price at £90 a side via the link below, but beware the £30 a side surcharge. so thats £240 quid for the calipers alone.
https://www.ebay.co.uk/itm/REAR-BRAKE-C ... 3641.l6368
Now if £240 doesn't turn you on, you could refurb them, but Rimmers don't appear to have any kits in stock, but ebay does at £28 a side.
https://www.ebay.co.uk/itm/Rover-MG-ZS- ... SwGUBaPWro
So say you don't want to pay the £240 and you don't want to refurb. You cold buy a used caliper, but expect to be buying a pair as obv they are sold as an upgrade most of the time and often with carriers, which you don't need.
Giving up on ZS180 spec entirely, you could downgrade to the standard basic 200/25/ZR caliper which are much more common and cheaper. However you will need the carriers and discs as well. The carriers will be common and cheap enough to obtain and so with the calipers, at least one side is £50 on Rimmers, you could find the other side on ebay new for around the same money with some shopping around.
PostPosted: Thu May 03, 2018 12:36 pm
I have a pair of 180 rear calipers and carriers
However
One of the calipers doesn’t “spring back” when you manually twist the handbrake bolt from above, couldn’t get a definite answer as to what the issue is with it so gave up
Unless anyone has any clues
Many thanks baz
