It is currently Mon Jul 23, 2018 1:15 am
Reply to topic  [ 20 posts ]
 TomCat turbo/216 GTI Dunlop race suspension
 Post subject: TomCat turbo/216 GTI Dunlop race suspension
PostPosted: Wed Nov 08, 2017 10:45 pm
Fri Sep 18, 2015 11:14 pm
Bedford, England
Just after and info if anyone has/knows! I want to get some coilovers ordered over Xmas for my Rover R8 I'm building to go circuit racing with just wondered if anyone knew spring rates of the original Rover coupe/gti Dunlop race cars to give me a rough starting point. Had a little nose on net doesn't seem must info about anymore, I'm probably going for AVO R2's which are supplied with there standard F250, R200 springs iirc unless you state otherwise which Imo is very weak.
 Post subject: Re: TomCat turbo/216 GTI Dunlop race suspension
PostPosted: Thu Nov 09, 2017 12:23 pm
Fri Feb 21, 2003 8:23 am
colchester
they were very high lb rates
fronts approx 1000-1200lb
rears approx 1400lb
Scott
ex: race dunlop rover turbo cup car
viewtopic.php?t=6228
feedback viewtopic.php?f=107&t=86737&start=0&hilit=tomcaT+FEEDBACK
PostPosted: Thu Nov 09, 2017 2:46 pm
Bedford, England
Think at that the chassis will crack :lol: Thanks for reply
PostPosted: Thu Nov 09, 2017 6:29 pm
I changed a lot of my zs suspension. Not quite the same but still good for the road (smooth ones).
I had 650 fronts and 450 rears.
Drew
PostPosted: Fri Nov 10, 2017 1:31 am
Bedford, England
Drew
Thanks other than a few shows hopefully wont be using it on roads much
PostPosted: Thu Nov 16, 2017 5:37 pm
you laugh but my roversport suspension is 1750 rear and 1000lb front . i had them measured .
is un useable on the road full stop . youd ruin the car within ten miles. im even tempted to ditch my roversport stuff and go for alot newer and softer springs . as i will mainly be runing the car on r88r etc
and yes the chassis does crack after a while hence the reinforcement plates in the main legs and the stich welding as per the roversport manual. even my road car n142 fdh . cracked in the main chassis legs even with avo coilovers on and 300 lb up front and 450 at the rear. no its in for a rebuild i am doing the reinforcement . but in hind site just shifting the stress else where .
matt who has my old car halfed them basically . and its still stiff.
but you forget the cars are designed to run slicks . and after a season or two they would proberbly just reshell the car anyway.
PostPosted: Fri Nov 17, 2017 2:26 pm
Bedford, England
Thanks for that, I do run slicks on track but will have to run list tyres as per regs when get running. You know if you can still get the rover sport manual anywhere?
PostPosted: Fri Nov 17, 2017 5:02 pm
i can stick a copy in my one drive for you if you like.
PostPosted: Fri Nov 17, 2017 10:15 pm
Tue Mar 04, 2003 8:20 pm
Straya (Australia)
The Coupe suspension is different to the GTI racer, the GTI was lighter with a Honda engine.
PostPosted: Sat Nov 18, 2017 1:20 am
Bedford, England
That would be great if not to much trouble
PostPosted: Sat Nov 18, 2017 1:21 am
Bedford, England
Very true was just looking for a rough starting point and couldn't find anything on the 216's
PostPosted: Mon Dec 04, 2017 5:29 pm
https://1drv.ms/b/s!Ans_TO5PFOArhjK6rR68H14wa_rp
roversport manual for any one who wants it
PostPosted: Tue Dec 05, 2017 12:28 pm
Bedford, England
Thanks mate :)
PostPosted: Wed Dec 06, 2017 12:10 am
Mon Aug 17, 2015 4:43 pm
Thanks for posting that, some very useful information in that :thumbup:
PostPosted: Wed Dec 06, 2017 5:10 pm
Bedford, England
Guess will be doing some welding before painting engine bay :o
PostPosted: Wed Dec 06, 2017 7:00 pm
Some plates on the bottom of the front turrett would be a good shout. Seen a few crack there.
Drew
PostPosted: Wed Dec 06, 2017 10:30 pm
Sat Apr 19, 2003 12:49 pm
In my garage
What is a great read, thanks for posting that up.
Rover 820
PostPosted: Thu Dec 07, 2017 2:20 pm
oh yes
had to put all the plates in for my road car as that had cracks left right and center lol
PostPosted: Fri Dec 08, 2017 1:29 pm
In my garage
Was there a triangular panel welded behind the front wing on the Coupe for the race cars?
Rover 820
PostPosted: Fri Dec 08, 2017 5:28 pm
yes there was
