It is currently Tue May 22, 2018 10:41 pm
Reply to topic  [ 4 posts ]
 MG ZS+ 1.8 Spares or Repair
 Post subject: MG ZS+ 1.8 Spares or Repair
PostPosted: Thu Nov 03, 2016 10:26 pm
Mon May 13, 2013 10:02 pm
Cheshire
I'm getting rid of my MG ZS. It'll go on ebay at the weekend but I'd thought I'd pop it on here just in case anyone fancies a winter project.
This car is spares or repair, priced at £75 as that's what the scrap man will give me.
Good Points
All work listed has been carried out since January this year when I purchased the car.
Complete new exhaust system (down pipe, cat, mid section, back box).
New head gasket (Payen BW750)
New head bolts.
New cambelt + tensioner.
New water pump + thermostat + seals.
Replaced one exhaust cam seal.
New exhaust/inlet gaskets.
New radiator.
New plugs.
New outer cv joints and boots.
MOTed until June 2017.
Bad Points
Running on 3 cylinders.
Normal age related dents and scratches.
Unusual rattle from engine bay on occasion when under load (related to misfire?).
Car was running great until about 3 months ago when it started using oil. Blue exhaust smoke became more and more noticeable.
I thought maybe it was just a stem seal but it's got progressively worse. Last month we bought a replacement car and I've just been using the ZS intermittently.
This past weekend it developed misfire on cylinder 1. Removed plug and it was caked in oil (other 3 were ok), cleaned plug but as soon as car was run again the fault returned and the plug was covered in oil again.
It may be repeated head gasket failure, maybe a stem seal, maybe a piston ring, I'm really not sure.
Now I have an alternative car and no real desire to bother with another K-series engine problem so the ZS needs to go.
Happy to answer any questions and can post up some better pictures at weekend if needed.
Note car is on BRM alloys in picture but it will come with 17" straights (unless you want to pay extra for alloys :p)
MG Maestro Turbo
 Post subject: Re: MG ZS+ 1.8 Spares or Repair
PostPosted: Fri Nov 04, 2016 11:34 am
Lol 75! That's crazy.
Where in the world are you?
Pic doesn't work for me. Reg and colour?
Sent from Drew @ Roverdose
PostPosted: Fri Nov 04, 2016 12:40 pm
Cheshire
Cheshire, CW9
It's an Mk1 03 plate in X-Power Grey. Lucas fobs.
Mileage is approx 115k
MG Maestro Turbo
PostPosted: Tue Nov 08, 2016 11:39 am
Cheshire
Now on eBay
http://www.ebay.co.uk/itm/322319182117
MG Maestro Turbo
