It is currently Sat Feb 24, 2018 1:03 pm
Reply to topic  [ 38 posts ]  Go to page 1, 2  Next
 Rover Fastenings Dimensions List project
 Post subject: Rover Fastenings Dimensions List project
PostPosted: Fri Feb 27, 2009 2:49 pm
Sun Feb 17, 2008 11:49 am
Near Swindon, Wiltshire.
Right.
Now it's crossed my mind a moment ago, because I don't know what length of bolt to buy for the water pump housing in my Vit, that it would be an invaluable resource to have a list of all the bolt sizes and lengths for pretty much the whole of each car.
So, here I am, may it do ya fine, and good folken, I seek aid and succor of you, yar.
I acknowledge that this is going to be a bit of a monster project, and furthermore, I acknowledge that that's a major understatement, however - I can but try.
I'm gonna write a list of cars, and engines, and folks, if you'd be so kind as to help me with this, any time you do a job on your beloved BL product, measure a bolt or two and help me out?
The first part is going to be generating a list of all the models, right down to trim levels, and just looking at this, I'm beginning to see how big a project this is going to be.
I'll start by just listing the more general names, but I hope to lay it all out in this sort of pattern;
- CAR --> BODY TYPE; (this if applicable, because for certain cars, the Metro, for example, it isn't). --> ENGINE --> TRIM LEVEL, followed by a simple list of set screw measurements in this pattern;
- FASTENING TYPE; (e.g - set screw/ bolt/ allen bolt, etcetera etcetera), DIAMETER --> HEAD SIZE --> LENGTH, (albeit with properly named descriptions, hopefully).
It will look quite repetitive for the moment, because I intend for it to be a full list, rather than just a crossover - rather than one of those tickbox affairs, a full list of bolt measurements for each and every car, so repeated bolt measurements are fine. Lord knows we've got the bandwidth, so let's make it as full a list as we can - that way, instead of having to cross-reference cars by a chart, we can just look down the list, find the car we want, look down that car's list of bolts and not have to fuss.
800s I've got help with, in the form of 800.info and Brad (mainly), but some of the other models I might have to ask for major help in listing all the models and trim levels that were made. 200s and Metros, just for example.
*Edit*
I also intend to mark them all up as set screws, rather than bolts, where possible. Unless shoulder length is specified, presume I've used a set screw.
I've also had a bit of a play to get the optimum length, and I reckon where known, bolt lengths can be split into overall, shoulder and thread, thusly;
- Yadda yadda, Bolt description goes here, y0 -
Fastening Type - | --> Diameter - | --> Head size - | --> Overall - | --> Shoulder - | --> Thread - |
Metro
- Hatchback -
- 111
- GSi
- GTi
- GTa
- 114
- GSi
- GTi
- GTa
R8
- Hatchback -
- 214 (K8 Carburettor)
- 214 (K8i)
- SLi
- Caliper Carrier Bolts -
Fastening Type - Bolt --> Diameter - M10? --> Head size - 17mm --> Overall - | --> Shoulder - | --> Thread - |
- SEi
- GSi
- 214 (K16i)
- 216 (K16i)
- 220 (T16i N/Asp)
- Water Pump Housing bolts -
Fastening Type - Set Screw --> Diameter - M6 --> Head size - 10mm --> Length 30mm
- 220 (T16i Turbo)
- Saloon -
- 414
- 416
- Coupé -
- 216 {SOHC D16i)
- 216 (DOHC D16i)
- 216 (K16i)
- 218 (VVC K16i)
- 220 (T16i)
- 220 Turbo (T16i Turbo)
600
- Saloon -
- 618
- 620 Ti (T16i Turbo)
- 620 SLi (H20i (?))
- 620 Si (H20i (?))
- GSi?
- 623 GSi (H23i)
800
Mk I
- Fastback -
- 820 (M16i N/Asp)
- 820
- E
- SE
- i
- Si
- SLi
- 820 Turbo "Tickford" (M16i Turbo)
- 825 D (VM)
- 827 (C27a)
- Si
- Vitesse
- Saloon -
- 825 (C25a)
- i
- Sterling
- 827 (C27a)
- Si
- SLi
- Sterling
Mk II
- Fastback -
- 820 (T16i)
- i
- Si
- SLi
- Sterling
- 820 Vitesse (T16i Turbo)
- 825 D (VM)
- Di
- SD
- SDi
- SLD
- 827 (C27a)
- i
- Si
- SLi
- Sterling
- Saloon -
- Coupe -
- 820 Sterling (T16i N/Asp)
- 825 Sterling (KV6)
- 827 (C27a)
Vard.
1994 Rover 820 Vitesse fastback
1995 Discovery 3.9 V8
<< Vard's Vouch Thread >>
______________________________________________________________________
 Post subject: Re: Rover Set Screw Dimensions List project
PostPosted: Fri Feb 27, 2009 2:56 pm
Events & Area Rep
Wed May 14, 2003 1:08 pm
Northern Ireland
They don't always use set-screws though. For example, the water pump doesn't use fully threaded bolts. I find that when replacing bolts it is the shank length that is more important to me because I can always cut down the thread part.
PostPosted: Fri Feb 27, 2009 3:00 pm
Valid point, Daz. Perhaps we should add fastening type to the list.
Yeah, I'll do that.
Hokay, edited.
Vard.
 Post subject: Re: Rover Fastenings Dimensions List project
PostPosted: Fri Feb 27, 2009 9:06 pm
Chris........ you have far, far too much free time on your hands :ermm:
PostPosted: Fri Feb 27, 2009 9:18 pm
You're crazy :o
srsly
PostPosted: Fri Feb 27, 2009 10:07 pm
Sat May 31, 2003 12:28 am
Nottingham
MarkCoupe wrote:
You're crazy :o
srsly
Needs a woman .. or a faster w4nking hand.
No longer a Rover owner :-(
Now driving a Honda 2.4 vtec estate and a Honda VFR 750.
Staying around for the LOLZ.
PostPosted: Fri Feb 27, 2009 10:21 pm
Sun Oct 08, 2006 9:52 pm
Cork, Ireland
Fairly thankless job Chris :( Best of luck with it though.
1990 414si, 1995 214SEi, 2005 Mondeo, 1999 618, 1995 Celica SSII,
1997 400 D, 1993 Prelude, 1992 W124 250d, 1993 520i,
1997 216 Tomcat, 2002 MG ZT 180+, 2008 Grand Cherokee 3.0CRD
PostPosted: Fri Feb 27, 2009 11:45 pm
Yeah, I do have the feeling I might just have assigned what I'm doing with the rest of my life.
Nevermind.
As I said, any and all help appreciated with this one...
Vard.
PostPosted: Sat Feb 28, 2009 8:46 am
Sun Sep 25, 2005 4:47 pm
stafford
you do realise your going to get bored of this very quickly :P
PostPosted: Sat Feb 28, 2009 7:24 pm
Yes, but I have almost infinite patience, so with luck, I might just survive...
:roll:
Vard.
PostPosted: Thu Mar 05, 2009 2:29 pm
Yes, but if you ever go on mastermind, your specialist subject will be fasteners lengths of 1990's Rovers :|
PostPosted: Thu Mar 05, 2009 7:28 pm
Which would be a bit sad. Nevermind.
Vard.
PostPosted: Thu Mar 05, 2009 8:22 pm
Mon Dec 27, 2004 11:17 pm
At the bridge, with Horatius.
At least you'd be able to set your own questions since no-one else would even begin to have a clue !!
"On a 1988 Rover 820 SE hatchback, what is unusual about the fixing screw located just beneath the front left hand indicator but above the bumper adjacent to the black and red trim running from the number plate to the trailing edge of the front wing ?"
PASS !
Stella now gone, Ruby is my baby now.
For your photography needs, try
http://www.freelancephotographic.net
PostPosted: Mon Apr 20, 2009 1:15 am
Fastening Type - | --> Diameter - | --> Head size - | --> Length - | :|
Fastening Type - | --> Diameter - | --> Head size - | --> Overall length - | --> Shoulder length - | --> Thread length - | :(
Fastening Type - | --> Diameter - | --> Head size - | --> Overall - | --> Shoulder - | --> Thread - | :)
Fastening Type - | --> Diameter - | --> Head size - | --> Overall - | --> Shoulder - | --> Thread - | :!: :D
Vard.
PostPosted: Mon Apr 20, 2009 1:46 am
Mon Mar 12, 2007 5:48 pm
Oxfordshire
Tbf it would be a usefull thing to have handy, especially seeing as XPart sell new bolts at rediculous prices and the nearest dealer involves a 45 mile round trip. When I had to buy new rear suspension bolts for the lower arms of my Coupe I had to fork out £3.62 + VAT for EACH bolt, that was like £16 for 4 bloody bolts!
Would also be an idea to put down the load rating of the bolts seeing as you have so much time on your hands :wink: :P
>>>Spec thread<<<
PostPosted: Mon Apr 20, 2009 1:48 am
F**k me Stef, I'm only human...
Plus, I seem to be getting a LOT of input here. Thanks for the help RT!
*[MASSIVE UNSUBTLE HINT]HELP MEEEEEEEE![/MASSIVE UNSUBTLE HINT]
Vard.
PostPosted: Mon Apr 20, 2009 1:52 am
Oxfordshire
Well where exactly are we supposed to know the details for the bolts from?! EPC and RAVE are useless when it comes to that, and the bolts themselves are usually equally useless only providing the load rating :wink:
>>>Spec thread<<<
PostPosted: Mon Apr 20, 2009 1:55 am
F**k knows.
Someone might do.
If they do, lett'm put it down.
Vard.
PostPosted: Mon Apr 20, 2009 11:24 pm
Next time I remove a bolt (however obscure and insignificant), I'll try to remember to measure it...
Are you happy for this to be your life's work? Would you like it read at your funeral?
PostPosted: Mon Apr 20, 2009 11:43 pm
Ok, this will seem strange but when doing the rear brake caliper carrier on the 800, the spanner/socket sizes are 8, 10, 12 and 14mm. Now, I thought that metric bolts of an even number diameter had odd numbered head sizes eg 13mm head on an 8mm bolt. Perhaps the EPC will give the bolt size but perhaps not the exact description.
I've bookmarked a US site which does bolts and setscrews and even goes into quite some detail about the different types.
http://www.boltdepot.com/Default.aspx
PostPosted: Tue Apr 21, 2009 2:24 am
Good move, Gordon.
To that, I think it's also a good idea to find the bookmark I've got on the screwfix page of bolts...
Screwfix Bolt shopping page
That's where I buy my bolts.
Vard.
PostPosted: Thu Apr 30, 2009 8:13 pm
Tue Oct 23, 2007 12:08 pm
Ayrshire
Anyone know what size of bolt thats is used on the 220 turbo coupe's front hubs
The one that keeps the shock in place pinch bolt i think its called
Part Number - RYG10039
PostPosted: Mon Jun 01, 2009 5:55 pm
Wed Dec 19, 2007 8:21 pm
leeds
Well said danny boy dont you think we spend enough time under our motors without booking an extra wk off for some measuring time lol,you weren't on the sauce when you thought up this humongus task was you :w00t: :lol:
Rover 220 sdi tractor pulling machine
Mk 2 ZS-T build thread...viewtopic.php?f=10&t=138376
PostPosted: Mon Jun 01, 2009 6:04 pm
leeds
Good move, Gordon.
Hey that links handy as my work Burdens has just gone into a partnership with screw fix so i wunt have to go far to order things sh1t i could order it whilst getting a coffee from our trade counter lol and it be delivered to me at work too no extra cost nice :D
PostPosted: Mon Jun 15, 2009 11:46 am
T16 oil pump to block bolts:
M6 x 30mm. 9mm shank, 8mm hex flanged head, eight off
M10 x 45mm. 15mm shank, 13mm hex flanged head, one off
PostPosted: Wed Jun 17, 2009 5:54 pm
Likely to be identical on all T16 applications, turbo and N/Asp also, Ant?
Vard.
PostPosted: Sat Jun 20, 2009 1:45 pm
Should be, me old mucker. Possibly L-series too as I think they use the same oil pump? Or it could be the crank oil seal I'm thinking about.
PostPosted: Sat Jun 20, 2009 4:24 pm
Vard, you can probably easily add the dims of the big end nuts and studs now as you wont need to dismantle much to get there :oops: :sorry:
PostPosted: Sat Jun 20, 2009 6:37 pm
stafford
ouch! lol
PostPosted: Sat Jun 20, 2009 11:37 pm
Right, got some more for you, me duck:
All T16, all grade 8.8, except for the adapater plate screws, which I can't remember, if they were indeed marked.
sump (steel):
M6 x 12mm, 8mm hex flanged head, 17 off
M6 x 24mm, 8mm hex flanged head, 1 off
Oil pick up pipe:
M6 x 12mm, 8mm hex flanged head, 1 off
M6 x 17mm, 8mm hex flanged head, 2 off
Sump oil drain:
M8, 13mm hex flanged nut, 2 off
Engine mount (to block):
M8 x 24mm, 10mm hex flanged head, 5 off
M8 x 55mm, 32mm shank, 10mm hex flanged head, 1 of
Aluminium pump housing to engine block:
M10 x 49mm, 20mm shank, 13mm hex flanged head, 5 off
M10 x 59mm, 29mm shank, 13mm hex flanged head, 1 off
M8 x 55mm, 30mm shank, 10mm hex flanged head, 1 off
M8 x 141mm, 107mm shank, 13mm hex head & plain washer, 1 off
Rear crank seal:
M6 x 16mm, 8mm hex flanged head, 5 off
Adapter plate to engine block:
M8 x 14mm, counter sunk head (18mm dia.), T50, 4 off
PostPosted: Mon Aug 31, 2009 10:56 pm
Sun Sep 17, 2006 11:08 pm
Unching in le harbogb
chris we need an update, the suspense of not knowing the latest rover fastening dimensions is killing me :D
will work for booze.
PostPosted: Sun Sep 06, 2009 2:10 am
I'll update YOU, you unpredictable batty...
Vard.
PostPosted: Tue Jan 26, 2010 6:21 pm
Thu Feb 21, 2008 5:30 pm
my own little world
jesus christ... your lack of taste in music suddenly became the least of my worries about you vard. :|
bolt sizes... seriously??
Rich_1988 wrote:
I unch in le harbogb
PostPosted: Tue Jan 26, 2010 6:33 pm
what
the
f**K.
PostPosted: Tue Jan 26, 2010 6:36 pm
