It is currently Mon Jul 16, 2018 9:33 pm
This topic is locked, you cannot edit posts or make further replies.  [ 7 posts ]
 Correct Gearbox oil for a PG1 box?
 Post subject: Correct Gearbox oil for a PG1 box?
PostPosted: Fri Aug 27, 2004 8:52 am
Mon Apr 28, 2003 1:03 pm
down south
Can anyone tell me what gearbox oil should be used in the Tomcat Turbo PG1 box (it's the one with the diff).
PostPosted: Fri Aug 27, 2004 9:35 am
Sat Mar 01, 2003 9:11 am
west midlands
MTF 94, it available from Rover, its around £17-18ish a can.
You get 2.5 ltrs in the Can, the box required 2.3 ltrs so its plently :)
S14a
PostPosted: Fri Aug 27, 2004 10:38 am
Trader
Trader
Wed Feb 26, 2003 5:27 pm
N.Wales
Use a synthetic 75w-90 (i used comma)
This stuff looked after my gearbox very well.
You can buy a 5 litre container of this for the same price as the rover stuff (around £18) from your local car parts distributer (partco or whatever).
HTH
Andy
Evo 8 RS - Drag Spec - 832 bhp ATW :o
Freelander 2 HSE/HST - Tow Bus
Back in the land of the 1/4 mile :)
PostPosted: Fri Aug 27, 2004 8:39 pm
west midlands
Sorry to Hijack the thread
What oil is the best one to use in the PG1 gearbox, MTF94 or 75w/90 :?
The reason i ask is, last week i changed my clutch, drained the box refilled it with MTF-94.
A week later my gearbox is dead :cry:
Im wondering if the change of oil played a factor in this?
The oil which came out the gearbox was a red colour??
I dont want it to happen again! Which oil should i use?
cheers Hetz
S14a
PostPosted: Fri Aug 27, 2004 9:07 pm
Wed Apr 23, 2003 2:40 pm
SW London UK
Rover started with 10/40 in the boxes and a change at 24 or 36K (can't remember now), then changed to the Honda spec oil MTF94 (Its a Honda design) around 94 ish, which is supposed to be fill for life.
According to the Witham oils website MTF94 is a fully synth 10/40, what else is in there I don't know.
most people are on MTF94, choice is yours.
George.
MK II Sterling Fastback in Gold with rust highlights on LPG (hells teeth the seat heater certainly works)
Ohh that was a long time ago, that's girders in China now...
PostPosted: Sat Aug 28, 2004 7:48 am
Sat Apr 19, 2003 10:12 pm
ATF at a guess
Rx-8 - Lowered,k&n filter(modified air box), Hiflow metal cat, Whiteline adjustable arb's & spherical links, AP underdrive pulley & lightweight alternator pulley....Revtastic
PostPosted: Sat Aug 28, 2004 9:52 am
Thu Feb 20, 2003 11:41 am
Rover recommend using a 10w 40 in all PG1 boxes fitted to the 2 litre engined Rover's. After 95-96, MTF94 was standard fill, basically the same grade but no need to change. Anyone using a different grade do so at their own risk, especially those with the ToRSen diff.
No need for any special fully-synthetic type either, mineral or semi is perfectly fine and FS is a waste of money. Gearbox oil change intervals were every 24k except on later car's where it was fill for life with MTF94.
Thicker oil is fine for a gearbox that has some wear, going to a 15w40 has some advantages. But it also makes the change stickier when cold.
Locking this post and making it a sticky, an all too common question that is asked every two hours :roll: :D
