It is currently Wed Feb 21, 2018 1:43 pm
Reply to topic  [ 7 posts ]
 Modded your Rover? Some good advice on oil!
 Post subject: Modded your Rover? Some good advice on oil!
PostPosted: Mon Sep 27, 2004 9:10 am
Fri Sep 24, 2004 9:31 pm
South West
If you are "modding" your car and adding BHP then consider your oil choice carefully as the stock manufacturers recommended oil will not give you the protection that your engine requires.
A standard oil will not be thermally stable enough to cope with higher temperatures without "shearing" meaning that the oil will not give the same protection after a couple of thousand miles as it it when it was new.
Let’s start with the fundamentals. An engine is a device for converting fuel into motive power. Car enthusiasts get so deep into the details they lose sight of this!
To get more power, an engine must be modified such that it converts more fuel per minute into power than it did in standard form. To produce 6.6 million foot-pounds per minute of power (ie 200 BHP) a modern engine will burn about 0.5 litres of fuel per minute.(Equivalent to 18mpg at 120mph). So, to increase this output to 300BHP or 9.9 million foot-pounds per minute it must be modified to burn (in theory) 0.75 litres.
However, fuel efficiency often goes out of the window when power is the only consideration, so the true fuel burn will be rather more than 0.75 litres/min.
That’s the fundamental point, here’s the fundamental problem:
Less than 30% of the fuel (assuming it’s petrol) is converted to all those foot-pounds. The rest is thrown away as waste heat. True, most of it goes down the exhaust, but over 10% has to be eliminated from the engine internals, and the first line of defence is the oil.
More power means a bigger heat elimination problem. Every component runs hotter; For instance, piston crowns and rings will be running at 280-300C instead of a more normal 240-260C, so it is essential that the oil films on cylinder walls provide an efficient heat path to the block casting, and finally to the coolant.
Any breakdown or carbonisation of the oil will restrict the heat transfer area, leading to serious overheating.
A modern synthetic lubricant based on true temperature-resistant synthetics is essential for long-term reliability. At 250C+, a mineral or hydrocracked mineral oil, particularly a 5W/X or 10W/X grade, is surprisingly volatile, and an oil film around this temperature will be severely depleted by evaporation loss.
Back in the 1970s the solution was to use a thick oil, typically 20W/50; in the late1980s even 10W/60 grades were used.
But in modern very high RPM engines with efficient high-delivery oil pumps thick oils waste power, and impede heat transfer in some situations.
A light viscosity good synthetic formulated for severe competition use is the logical and intelligent choice for the 21st century.
You should seriously consider a "true" synthetic for "shear stability" and the right level of protection.
Petroleum oils tend to have low resistance to “shearingâ€
Use the code ROVER and get 10% Club Discount
oilman's website: http://www.opieoils.co.uk/ - register for news and offers
email: sales@opieoils.co.uk
phone: 01209 202944
PostPosted: Mon Sep 27, 2004 6:12 pm
Mon Aug 18, 2003 9:48 pm
Lifting Off.....
Also a good idea to use an oil cooler if revving higher or making a lot more power. Especially if you are to be driving hard all the time.
i.e track use.
216 Coupe..Gone but not forgotton
'02 Fiesta Zetec-S (Sold)
306 GTI-6 - 140BHP A.T.W @7100RPM
(173 BHP @The Fly for pub talk)
PostPosted: Mon Sep 27, 2004 6:19 pm
South West
Certainly and you will be able to use thinner oils as a consequence as you will be running lower temps.
Also consider that a cooler may not be necessary if you use a thermally stable "true" synthetic oil as it will operate between 90 and 110 degC with the ability to use it for prolonged periods (track) at 130 degC.
Simon
phone: 01209 202944
PostPosted: Mon Sep 27, 2004 7:05 pm
Thu Feb 20, 2003 12:26 am
VTAK le' Teg
Superb thread
PostPosted: Mon Sep 27, 2004 10:31 pm
Wed May 28, 2003 11:17 am
I bought my oil from Opieoils and it rocks :)
PostPosted: Mon Sep 27, 2004 10:33 pm
Fri Feb 21, 2003 10:39 am
West London/Middx
I think this needs to be made sticky.
Roverlessness - what a strange feeling!
PostPosted: Mon Sep 27, 2004 11:21 pm
Wed Feb 19, 2003 9:50 am
In Somerset
excellent info! :) will move to the FAQ's
Was: 1994 Rover 220 Coupe Turbo
Now: 2010 SEAT Leon Cupra
