It is currently Mon Jan 22, 2018 11:37 am
 Rover 1.4 16v K series Technical data
 Post subject: Rover 1.4 16v K series Technical data
PostPosted: Thu Apr 06, 2006 7:36 pm
VEHICLE IDENTIFICATION
Engine code 14k16
Number of cylinders: 4/DOHC
Capacity cm3: 1396
Output:kw (din hp) RPM:::: 76 (103) 6000
Ignition system Description: MAP-i
Trigger location: crankshaft
Fuel system:
Make: Motorola
Type: MEMS 1,9
Description: MFI-s
Air metering Type: MAP
TUNEING AND EMISSIONS
Ignition coil:
Primary resitance ohms: 0,63-0,77
Fireing order: 1-3-4-2
Ignition timeing BTDC: Engine/rpm 10+5/875 Not adjustable
Idle speed rpm: 875+50
Oil temp for CO test degrees C : 70
CO content at idle tail pipe Vol.% : 0,5 Max
CO2/O2 content at idle speed Vol.%: 14,5-16/0,1-0,5
HC content at idle speed ppm: 100
Oil presure Bar/rpm: 7,0/6500
LUBRICANTS AND CAPACITIES
Engine oil Grade: SAE 10W/40
Alternative: SAE 10W/30
Engine capacity with filter: 4.5 litres
Gearbox oil grade: SAE 75W/80W
Gearbox fluid capacity : 1.8 litres
Brake fluid Type: DOT 4
Brake fluid capacity: 1 litre
Power steering fluid Type: Dexron ll
Power steering fluid capacity: 0.3 litres
FUEL SYSTEM
Fuel pump delivery presuer BAR: 4.1
System presure without vacume BAR: 2,8-3,2
TIGHTNING TORQUES
Cylinder head
Stage1: 20NM
Stage2: 180 degrees
Stage3: 180 degrees
Tightning sequence
CAM PULLY END (9) (5) (1) (3) (7)
CAM PULLY END (10 (6) (2) (4) (8 )
Main bearings:
Stage 1: 5 NM
Stage 2: 30 NM
Big end bearings:
Stage 1: 20 NM
Stage 2: 45 degrees
Sump bolts: 10 NM
Sump drain bolt: 42 NM Alu= 25NM
Flywheel/Driveplate: use new bolts tighten to 85NM
Clutch to flywheel: 18 NM
Crankshaft pully / damper: 205 NM
Camshaft sprocket / gear: M8= 35 NM M10 = 65 NM
Camshaft carrier / cap :10 NM
Camshaft / rocker cover 10 NM
Inlet manifold to cylinder head: 25 NM
Exhaust manifold to cylinder head: 45 NM
Spark plugs: 27 NM
Oxygen sensor (lambda) : 55 NM
Front hub: 180 NM
Rear hub: 185 NM
Steering rack to rod end: 45 NM
Brake caliper to carrier FRONT: 27 NM
Brake caliper carrier to hub FRONT : 108 NM
Brake caliper to carrier REAR : 27 NM
Brake caliper carrier to hub REAR: 108 NM
Road wheels: 110 NM
Hope this helps :mrgreen:
