It is currently Sat Jun 23, 2018 3:57 am
 Rover 827 V6 Technical data
 Post subject: Rover 827 V6 Technical data
PostPosted: Thu Apr 06, 2006 8:24 pm
VEHICLE IDENTIFICATION
Engine code V6-2,7
Number of cylinders: 6/OHC
Capacity cm3: 2675
Output:kw (din hp) RPM:::: 124 (169) 5900
Ignition system Description: MAP-i
Trigger location: distributer,crankshaft
Fuel system:
Make: honda
Type: PGM-Fi
Description: MFI-s
Air metering Type: MAP
TUNEING AND EMISSIONS
Fireing order: 1-4-2-5-3-6
Ignition timeing BTDC: Engine/rpm 15+2/680
Idle speed rpm: 680+50
Oil temp for CO test degrees C : 70
CO content at idle tail pipe Vol.% : 0,1 Max
CO2/O2 content at idle speed Vol.%: 14,5-16/0,1-0,5
HC content at idle speed ppm: 100
Oil presure Bar/rpm: 3.4 min/3000
Radiator cap Bar: 1
Thermostat opens degrees C : 78
LUBRICANTS AND CAPACITIES
Engine oil Grade: SAE 10W/40
Alternative: SAE 10W/30
Engine capacity with filter: 4.5 litres
Gearbox oil grade: SAE 10W/40
Gearbox fluid capacity : 2.3 litres
Automatic fluid: Dexron ll
Automatic fluid capacity: 3.2 litres
Brake fluid Type: DOT 4
Power steering fluid Type: Dexron ll
Power steering fluid capacity: 1.3 litres
FUEL SYSTEM
Fuel pump delivery presuer BAR: 4.1
System presure without vacume BAR: 2.5
Regulated presure with vacume BAR : 2
TIGHTNING TORQUES
Cylinder head
Stage1: 40 NM
Stage2: 50 NM
Stage3: 68 NM
Tightning sequence
CAM PULLY END (7) (3) (1) (5)
CAM PULLY END (8 ) (4) (2) (6)
Main bearings Tighten bolts as follows:
Bolts 1-8 = 41 NM
Bolts 9-16 =68NM
Bolts 17-24 = 50 NM
Bolt order
(17)..(19)..(21)..(23)
(1).....(3)....(5)....(7)
(14)..(10)...(12)..(16)
(13)...(9)....(11)...(15)
(2)....(4)....(6).....(8 )
(18 )...(20)..(22)...(24)
Big end bearings:
Stage 1: 20 NM
Stage 2: 50 NM
Sump bolts: 12 NM
Sump drain bolt: 45 NM
Flywheel/Driveplate: 105 NM / 75 NM
Clutch to flywheel: 26 NM
Crankshaft pully / damper: 115 NM
Camshaft sprocket / gear: 32 NM
Inlet manifold to cylinder head: 22 NM
Exhaust manifold to cylinder head: 45 NM
Spark plugs: 27 NM
Oxygen sensor (lambda) : 45 NM
Front hub: use new nut and tighten to 415 NM
Rear hub: Use new nut and tighten to 245 NM
Steering rack to rod end: 44 NM
Brake caliper to carrier FRONT: 33 NM
Brake caliper carrier to hub FRONT : 75 NM
Brake caliper to carrier REAR : 33 NM
Brake caliper carrier to hub REAR: 45 NM
Road wheels: 110 NM
Hope this helps :mrgreen:
