It is currently Sat Feb 24, 2018 1:02 pm
 Rover 825 KV6 Technical Data
 Post subject: Rover 825 KV6 Technical Data
PostPosted: Thu Apr 06, 2006 9:06 pm
VEHICLE IDENTIFICATION
Engine code KV6
Number of cylinders: 6/DOHC
Capacity cm3: 2497
Output:kw (din hp) RPM:::: 129 (175) 6500
Ignition system Description: MAP-iDIS
Trigger location: cam,crankshaft
Fuel system:
Make: rover
Type: mems
Description: MFI-s
Air metering Type: MAP
TUNEING AND EMISSIONS
Ignition coil primary resitance : 0.40-0.61
Fireing order: 1-6-5-4-3-2
Ignition timeing BTDC: Engine/rpm 15+2/750
Idle speed rpm: 750+50
Oil temp for CO test degrees C : 80
CO content at idle tail pipe Vol.% : 0,5 Max
CO2/O2 content at idle speed Vol.%: 14,5-16/0,1-0,5
HC content at idle speed ppm: 100
Oil presure Bar/rpm: 3.0/3000
Radiator cap Bar: 1.05
Thermostat opens degrees C : 78-82
LUBRICANTS AND CAPACITIES
Engine oil Grade: SAE 10W/40
Alternative: SAE 10W/30
Engine capacity with filter: 5 litres
Gearbox oil grade: SAE MTF94
Gearbox fluid capacity : 2.3 litres
Automatic fluid: Texaco N402
Automatic fluid capacity: 3.2 litres
Brake fluid Type: DOT 4
Power steering fluid Type: Dexron ll
Power steering fluid capacity: 1.5 litres
FUEL SYSTEM
System presure without vacume BAR: 3.0+0.2
TIGHTNING TORQUES
Cylinder head
Stage1: 12 NM
Stage2: 25 NM
Stage3: 90 degrees
Stage4: 90 degrees
Tightning sequence
CAM PULLY END (8 ) (4) (1) (5)
CAM PULLY END (7) (3) (2) (6)
CAM PULLY END (6) (2) (3) (7)
CAM PULLY END (5) (1) (4) (8 )
Main bearings Renew bolts
And tighten as follows
Stage1: 20 NM
Stage2: 90 degrees
Tighten in order below
Bolt order
(8 )....(4)......(2)......(6)
(16)...(12)....(10)....(14)
(15)...(11)....(9)......(13)
(7).....(3)......(1)......(5)
Big end bearings:
Stage 1: 20 NM
Stage 2: 45 degrees
Oil pump to block: 9 NM
Sump bolts: 25 NM
Sump drain bolt: 28 NM
Flywheel/Driveplate: 100 NM / 75 NM
Clutch to flywheel: 23 NM
Crankshaft pully / damper: 160 NM
Camshaft sprocket / gear: 27 NM + 90 degrees
Inlet manifold to cylinder head: 25 NM
Exhaust manifold to cylinder head: 45 NM
Spark plugs: 27 NM
Oxygen sensor (lambda) : 40 NM
Front hub: 395 NM
Rear hub: 245 NM
Steering rack to rod end: 39 NM
Brake caliper to carrier FRONT: 33 NM
Brake caliper carrier to hub FRONT : 75 NM
Brake caliper to carrier REAR : 33 NM
Brake caliper carrier to hub REAR: 40 NM
Road wheels: 110 NM
Hope this helps :mrgreen:
