It is currently Mon Jul 16, 2018 7:59 am
Reply to topic  [ 1 post ]
 Rover 1.6 16v K series Technical data
 Post subject: Rover 1.6 16v K series Technical data
PostPosted: Sat Apr 08, 2006 10:52 am
VEHICLE IDENTIFICATION
Engine code K16-1.6
Number of cylinders: 4/DOHC
Capacity cm3: 1589
Output:kw (din hp) RPM:::: 82 (111) 6000
Ignition system Description: MAP-i
Trigger location: crankshaft
Fuel system:
Make: Rover
Type: MEMS
Description: MFI-i
Air metering Type: MAP
TUNEING AND EMISSIONS
Ignition coil:
Primary resitance ohms: 0,71-0,81
Fireing order: 1-3-4-2
Ignition timeing BTDC: Engine/rpm 10+5/875 Not adjustable
Idle speed rpm: 875+50
Oil temp for CO test degrees C : 80
CO content at idle tail pipe Vol.% : 0,5 Max
CO2/O2 content at idle speed Vol.%: 14,5-16/0,1-0,5
HC content at idle speed ppm: 100
Oil presure Bar/rpm: 7,0/6500
LUBRICANTS AND CAPACITIES
Engine oil Grade: SAE 10W/40
Alternative: SAE 10W/30
Engine capacity with filter: 4.5 litres
Gearbox oil grade: SAE 75W/80W
Gearbox fluid capacity : 1.8 litres
Brake fluid Type:super DOT 4
Brake fluid capacity: 1 litre
Power steering fluid Type: Dexron ll
Power steering fluid capacity: 0.3 litres
FUEL SYSTEM
Fuel pump delivery presuer BAR: 4.1
System presure without vacume BAR: 2,8-3,2
TIGHTNING TORQUES
Cylinder head
Stage1: 20NM
Stage2: 180 degrees
Stage3: 180 degrees
Tightning sequence
CAM PULLY END (9) (5) (1) (3) (7)
CAM PULLY END (10 (6) (2) (4) (8 )
Main bearings:
Stage 1: 5 NM
Stage 2: 30 NM
Big end bearings:
Stage 1: 20 NM
Stage 2: 45 degrees
Poil pump to block: 9 NM
Sump bolts: 10 NM
Sump drain bolt: 42 NM
Flywheel/Driveplate: use new bolts tighten to 85NM
Clutch to flywheel: 18 NM
Crankshaft pully / damper: 205 NM
Camshaft sprocket / gear: 35 NM
Camshaft carrier / cap :9 NM
Camshaft / rocker cover 10 NM
Inlet manifold to cylinder head: 25 NM
Exhaust manifold to cylinder head: 45 NM
Spark plugs: 27 NM
Oxygen sensor (lambda) : 55 NM
Front hub: Use new nut and tighten to 181 NM
Rear hub: Use new nuts and bolts tighten to 181 NM
Steering rack to rod end: 39 NM
Brake caliper to carrier FRONT: 27 NM
Brake caliper carrier to hub FRONT : 108 NM
Brake caliper to carrier REAR : 27 NM
Brake caliper carrier to hub REAR: 108 NM
Road wheels: 110 NM
Hope this helps :mrgreen:
