It is currently Wed Jul 18, 2018 6:05 am
 What boost does my 200PS T16 Turbo run??
 Post subject: What boost does my 200PS T16 Turbo run??
PostPosted: Mon Jan 12, 2004 10:37 pm
Thu Feb 20, 2003 11:41 am
Now here's the definitive answer, this is taken from the Rover AutoCourse data manual in 1995 for a Vitesse Sport, which is identical to all 200PS engine in terms of boost control. For the 180 Vitesse version's, i have been reliably informed that maximum boost is 8.8psi.
PostPosted: Mon Jan 12, 2004 11:00 pm
Fri Feb 21, 2003 1:59 am
Doncaster
I thought it was common knowledge the boost of the 200PS engines was approx 6psi increased to approx 11psi via BMV.
Nice peice of info though :D
PostPosted: Mon Jan 12, 2004 11:04 pm
No it isn't, it's a common enquiry, hence this posting which should be put into a technical archive to save me having to say it every 5 minutes :roll:
Gareth
PostPosted: Tue Jan 13, 2004 10:11 pm
Sat Apr 19, 2003 12:34 pm
Worcerstershire
Perhaps you could include on the sticky what the 180 runs as well and the differences. This all to often a common question.
Audi B6 S4 Avant
Rover 221 coupe turbo 255.5bhp & 256.1lbs/ft (in the garage)
Rover 214 Mk3 Turbo Conversion (in bits)
Rover 416 GSi (in the garden)
PostPosted: Mon Apr 26, 2004 12:08 pm
To update, the STD Vitesse engine (known as the 180 model) uses 8.8psi of modulated boost as opposed to the 11.5psi of the 200PS engine.
Gareth
PostPosted: Mon May 31, 2004 2:53 pm
Sat Apr 17, 2004 9:16 pm
Rome, ITALY
hi guy :)
i've read the following data on my apexi:
at 2100 rpm = 0,75 kg/cm2
at 3500 rpm = 0,60 kg/cm2
at 6500 rpm = 0,85 kg/cm2
the boost curve si very strange in this motor!! go up at 2100 rpm, after it go down until ~ 4000 rpm, after it up again until 0,85 kg/cm2 at rev limit!!!
Now i understand beacause t16 engine have a flat torque curve!
bye!!
