It is currently Mon Jun 25, 2018 7:03 am
Reply to topic  [ 58 posts ]  Go to page 1, 2  Next
 Marty's Stock Rod Build
 Post subject: Marty's Stock Rod Build
PostPosted: Fri Oct 27, 2017 6:47 pm
Starting this thread for those who may be interested and something a bit different.
Having raced on the oval for quite a few years and gave up a few years back after racing Lightning Rods , Mondeo Rods and stock cars decided I missed the hobby so have decided to build myself a car I have built oval racing cars in the past.
The formula I'm going into is Stock Rods these are a stripped out de-skinned hatch back vehicle running 1400cc Race engines.
For those who don't know what stock rods are it's these
https://youtu.be/lANmfAUwn1U
So for that I'll need a vehicle and my choice is a Vauxhall Corsa C it's got to be fully stripped and caged ECT the engine that's show in the pictures below will be removed as it's no good for me at all. I had a few hours on the car tonight and the pics below will show where I'm upto and where I started.
My boy is also getting involved in the build and once he has grown a bit more I'll build him a Junior Rod it's basically the same cage ECT apart from they only run a 1000cc none tuned engine.
I hope you enjoy this log it will take a while to build as there is a lot to do ImageImageImageImageImageImage
These pictures will give you and idea what the cage is going to be like and the last picture will hopefully be my end goal all be it sign writing/sponsors will be different but will look basically the same.
Sent from my SM-G935F using Tapatalk
 Post subject: Re: Marty's Stock Rod Build
PostPosted: Fri Oct 27, 2017 9:03 pm
Mon May 13, 2013 10:02 pm
Cheshire
Looking forward to this thread progressing. Good to see you back Marty :)
MG Maestro Turbo
PostPosted: Sat Oct 28, 2017 6:51 pm
Got on with the stock rod today and it was put on a diet !!! Made good progress the de-skinning is only rough cut and will all be tidied up so nice and neat here is a few pictures showing how the day went also got the fuel tank removed and a lot of the inside work continues tomorrow.......
PostPosted: Sat Oct 28, 2017 10:26 pm
Cool
My old man used to be british champion in stock cars in the 80s, super stox i think he raced?
alfasuds and fiestas iirc was along time ago
PostPosted: Sat Oct 28, 2017 11:13 pm
Good project marry, good to see you getting back in to it :thumbup:
PostPosted: Sun Oct 29, 2017 8:23 pm
Another day on the stock rod started of like this
And by the end of today it was like this
Engine removed as not running that
Finished of the stripping inside and removing sound denting some still left to do
The bonnet also needed to go on a diet so that got de-skinned still got the boot to do
All in all not a bad weekend on it and it's just about ready for me to start caging it after a few more bits are removed :)
PostPosted: Mon Oct 30, 2017 8:04 pm
Not much happened today but a few items have arrived for the build
Sabelt 6 point harness Image
Pop of steering wheel boss
Steering wheel
Starting and accessory pannel for main ignition , fan , fuel pump and guage illumination
New ignition system wiring to go from distributor to ignition module
Main kill switch for emergency use Image
PostPosted: Wed Nov 01, 2017 12:48 am
A few hours on the car after work tonight how the evening started
How the evening finished
Front removed and wings
Tidied up round filler neck hole
Started removing one of the rear pannel skins to loose some more weight and makes it easier to straiten should I get a knock from behind
Removed some more of the floor bracings
Rear bumper removed
Not a bad few hours on the car :)
PostPosted: Wed Nov 01, 2017 9:18 pm
A couple of hours on the car tonight after work again and this how it was
This how it is now even less left the car is now nice and light still got a couple of bits to remove.
PostPosted: Sun Nov 05, 2017 1:55 am
A little update :)
removed all the glass and put the boot on a diet.
There is not much more left to remove now
Got the engine on the stand today
And removed the exhaust maunfold and rocker cover to expose camshaft and remove camshaft pully
Then undo head bolts 2 snapped in the block but machine shop soon sort that then remove cam carrier this exposes the rockers and lifters so remove all them as well
And then pull head off marked pistons so know there origional cylinder
Next was sump of to expose con rods and crank result the sump is already baffled
Undo all the conrod bolts and pop pistons out and remove oil pick up pipe
This left just the crank in place remove the crank caps and you left with this
Lift crankshaft out and remove bearings and you are left with a bare block
When removing the oil pick up this is exactly why you should not go shoving loads of sealer anywhere near oil ways or sump ECT!!!Image
That's just asking for oil starvation leading to engine failure !!
Jobs that need doing
Bores checked and honed
Broken studs from block removed
Block face machined
Head face machined
3 angled valve seats machined
Cam carrier re-faced
Crank polished as it has a few marks nothing majot
New rings
New camshaft and adjustable vernier
Solid lifters
New rocker arms
New water pump
New cambelt kit
New ends and mains
New high pressure oil pump
Full gasket and seal set
Good clean of all parts and a lick of paint
And we should just about be there ......
PostPosted: Sun Nov 05, 2017 4:41 pm
Mon Dec 21, 2015 4:58 pm
Wigan
Looks very interesting.
Wish I had the time / space for something like this, keep up with the updates :)
PostPosted: Tue Nov 07, 2017 12:50 am
Picked a seat up tonight kirkey intermediate :)
This is what's under the cover
Nice and light and plenty of support due to the shape :)
PostPosted: Tue Nov 07, 2017 12:58 pm
Loads of great work done their as always marry, my oil pick up pipe was fully clogged on my old forge lump..... something Defford worth cheaking.
PostPosted: Tue Nov 07, 2017 10:52 pm
I just make sure I'm very sparing with sealer here is my choice of cam spec It will be a tad lumpy and some nice lift haha
There is still a lot to do as I'm fussy and like to pay attention to detail so will hopefully be a work of art once done I won't want to scratch it haha
PostPosted: Sat Nov 11, 2017 7:02 pm
Had a few hours on the car today and managed to trim some more weight out of it !!!
Cross bracings on floor removed and pillar bracings removed
Pillar bracing in place
And with it removed
This all what was removed today
And gave the inside a good clean out ready for cage now that's next
All cuts still need cleaning up and made tidy but they can be done after the cage is all in its coming on now :)
PostPosted: Sun Nov 12, 2017 12:51 pm
Wed Aug 09, 2006 6:18 pm
Near Mansfield, Notts
How much does the shell weigh now? Have you got a way of checking?
Clearly you rely entirely on the cage for any strength as the car shell is just a skin now pretty much.
PostPosted: Sun Nov 12, 2017 2:42 pm
Yeah the cage ties everything together as it is pretty much just a skin now
It does not weigh much at all once it is built it will be going on the scales to be setup and corner weighted so will know how much it weights then
PostPosted: Tue Nov 14, 2017 10:08 pm
Had a good session on the car and got arches and skirts fitted it's starting to take shape now :)
PostPosted: Wed Nov 15, 2017 10:46 pm
Few hours on it tonight so time to fit the rear bumper and side supports
Next I have started to blend arches and skirt to the car looks better
Next was some more weight saving !! Now you probably thinking not possible but it was the passenger door has been skinned
Also there is no need for a door handle so I have removed that you will see the plate put over the hole in above picture and this is it finished after a bit of filler
So not a bad few hours on the car another step closer :)
PostPosted: Thu Nov 16, 2017 7:33 pm
Things are moving along well I have mounted the passenger door skin and have mounted the boot and front bumper
Brackets in place that are drilled and tapped 6mm to take the bolts
And door skin bolted in place
Next is the front bumper plates added and front bumper secured
The top section of bumper / grill I'll pick up of bonnet posts I'll show that in another update when I come to that part Image
PostPosted: Sat Nov 18, 2017 8:41 pm
Had a good day on the car today and started to get the cage in its finally starting to look something :)
PostPosted: Sun Nov 19, 2017 6:20 pm
Wigan
Looking great mate. Keep it up :D
PostPosted: Sun Nov 19, 2017 8:27 pm
Had another good day on it today front turret supports , steering column and started the lower half of drivers side chick bars.
The seat loosely laid in and got to be mounted properly yet
PostPosted: Fri Nov 24, 2017 1:15 am
Got the seat and centre screen bar fitted tonight ignore the big bolts on seat they was used just as a mock they will be changed for shorter ones. Still got to add a bar to brace the rear of the seat that will be shown in a later update :)
PostPosted: Sat Nov 25, 2017 6:23 pm
The cage is finally complete and the seat pic ups on the cage added.
Just got to add harness mounting points to the cage yet
PostPosted: Mon Nov 27, 2017 10:21 pm
Let there be paint on the inside :)
It's not 100% perfect but that will do its a race car not a show car :)
And that's me done for the night.
PostPosted: Tue Nov 28, 2017 2:58 am
Mon Aug 17, 2015 4:43 pm
You've spent all that time trimming as much metal out as possible, then you've gone and put a layer of paint on everything!!! You'll have to shave all the hair of your entire body to compensate :lol:
Great progress with the car though, wish I had the time... when does the season start?
PostPosted: Tue Nov 28, 2017 9:37 am
Rrobson wrote:
You've spent all that time trimming as much metal out as possible, then you've gone and put a layer of paint on everything!!! You'll have to shave all the hair of your entire body to compensate [emoji38]
The season starts in March so plenty of time left :)
PostPosted: Tue Nov 28, 2017 1:39 pm
Looking great marty, how's the engine build going?
PostPosted: Tue Nov 28, 2017 9:51 pm
I've not got bits back from machine shop yet and need to get car ready before I worry about engine.
Nothing major to report on progress wise apart from fuel line been fitted
Didn't have much time tonight so made the most of what I had anything done is another step forward :)
PostPosted: Sat Dec 02, 2017 8:03 pm
The colour is on it will come to life more once it's lacquered
Tomorrow I'll paint the doors , boot and bonnet and then a case of bolting them on.
I'll paint the engine bay when I do the dash pod as that's going to be green :)
PostPosted: Mon Dec 04, 2017 1:26 am
Another day over will now leave it a few days and give it a good mop over another couple of small bits to paint but nothing major
I'll be glad when the paintwork is done :)
PostPosted: Mon Dec 04, 2017 10:03 pm
Nothing like a bit of paint mopping :)
Takes a while but it's worth it for the finish :)
PostPosted: Mon Dec 04, 2017 10:13 pm
Cool project, paints come up a treat after a polish :thumbup:
PostPosted: Thu Dec 07, 2017 9:19 pm
Had a couple of hours on the car tonight and front bumper and engine bay painted at last.
Users browsing this forum: No registered users and 4 guests
