It is currently Mon Jun 25, 2018 10:53 am
Reply to topic  [ 58 posts ]  Go to page Previous  1, 2
 Marty's Stock Rod Build
 Post subject: Re: Marty's Stock Rod Build
PostPosted: Thu Dec 07, 2017 11:42 pm
Wed Aug 09, 2006 6:18 pm
Near Mansfield, Notts
You have some skills to do what you have done to the car. Is all of the effort to then smash it up in a race?!
PostPosted: Fri Dec 08, 2017 12:34 am
Thanks I don't do to bad :)
Noooo it's a Stock Rod so a none contact formula so all be it you get some scuffs and knocks ECT it should last a few years easy it's not a banger :)
Sent from my SM-G935F using Tapatalk
PostPosted: Fri Dec 08, 2017 8:36 pm
Dash all painted a quick wipe over and it's ready for sign writing it's now time to get it built up :)
Coming along nicely :)
PostPosted: Sat Dec 09, 2017 11:15 am
Epic work at such a fast pace 8)
PostPosted: Thu Dec 14, 2017 10:01 pm
All ready for sign writing tomorrow can't wait to have it done should be a good update tomorrow :)
PostPosted: Sat Dec 16, 2017 3:11 am
Been a very long day but all sigh writing is finally done and the sign writer has done a cracking job I'll let the pictures do the talking :)
PostPosted: Sun Feb 11, 2018 5:40 pm
Bit of an update had not done much recently due to being ill.
Main Live and Earth cables all fitted.
Gearbox is now rebuilt and back in with locked diff and the correct Diff and 2nd gear ratio.
Also have the dash all built up and just a few bits left to do on the wiring.
It's getting there slowly but surely.ImageImageImage
Car needs a good clean out inside but it's getting there [emoji16]
PostPosted: Sun Feb 11, 2018 8:10 pm
Mon Feb 22, 2010 9:51 pm
WIRRAL
Just gone through this, cracking build mate ! :thumbup:
Is that a Mk2 Astra indicator on the dash lol ? :lol:
PostPosted: Sun Feb 11, 2018 9:06 pm
ROVER-25X wrote:
Just gone through this, cracking build mate ! [emoji106]
Is that a Mk2 Astra indicator on the dash lol ? [emoji38]
Close it's a Nova side repeater makes an ideal oil pressure warning light [emoji38]
PostPosted: Sun Feb 11, 2018 9:34 pm
WIRRAL
Lol, i'll take it, nice touch though.
PostPosted: Sun Mar 18, 2018 1:44 am
Time for another update a fair bit been done
Dash complete
Seat fitted
Harnesses fitted
Fuel tank fitted
Fuel pump fitted
Firewall fitted
Ignition module fitted
Ignition system tested and sparking
Coil fitted
Gearbox earth to chassis
Charging point for battery made
Breather fitted
Roof colour grading added
Roof number added
Window net added
Alloy footwell and foot rest added
itImage
Lower arm made with ball joint moved for stagger and camber
Think that's about it for minute :)
PostPosted: Sat Mar 24, 2018 11:04 pm
WIRRAL
Its all these little bits that can consume your time too, how did you get on time wise with all these ?
PostPosted: Tue Mar 27, 2018 10:43 am
Sat Mar 05, 2011 1:01 am
leeds
Looking good Marty looks almost done! Well done should be a beast!
PostPosted: Wed Mar 28, 2018 4:38 pm
I have been doing it evenings after work and weekends and is nearly there still waiting on engine to come back from machine shop
Got the suspention on the other night it now sits like a stock rod and has the camber to N/S/F wheel
The car now runs 2.25 springs that way I can easily alter the length and lb of spring if i need to tweek the handling I should not be to far of with the length an lb I have chosen.
The car also now on Gaz shocks all round which are valved correctly for a stock rod.
If you look you will see the car leans to O/S/F as I race in a clockwise direction
Here is the camber added
I have since tidied the garage up as it was looking a right mess
PostPosted: Wed Mar 28, 2018 6:16 pm
WIRRAL
Oh god don't remind me, I have two, both bombsites. :(
PostPosted: Thu Mar 29, 2018 10:41 am
leeds
That makes 3! Really need to get round to sorting my logger out! That's some serious camber Marty! Should be good fun!
PostPosted: Tue Apr 10, 2018 8:56 pm
A few upto date pictures and one set of wheels painted ..ImageImageImageImageImageImageImageImage
Still waiting on engine to come back from machine shop.....
PostPosted: Wed Apr 11, 2018 12:36 am
WIRRAL
Not keen on the rims but they look mint.
PostPosted: Wed Apr 11, 2018 2:20 am
They are used on the inside O/S as they are ET49
On the outside N/S I will run a different style that's ET13
It's not about looks it's about offset and J as it makes a huge difference how a car will handle on the oval
PostPosted: Wed Apr 11, 2018 2:25 am
These are the outside wheels and you can see the difference
PostPosted: Sat Apr 14, 2018 8:51 pm
Inside wheels fitted looking like a stock rod now [emoji16]ImageImage
PostPosted: Sat May 26, 2018 11:10 am
Little bit of an update been very busy with other things but the engine is slowly coming together
Coming together nicely
PostPosted: Sun May 27, 2018 7:23 pm
WIRRAL
Engine is progressing nicely mate. :D
Users browsing this forum: Google [Bot] and 4 guests
