It is currently Fri Jun 22, 2018 11:49 pm
Reply to topic  [ 8 posts ]
 Needs some help with Metro track rod end parts
 Post subject: Needs some help with Metro track rod end parts
PostPosted: Mon Sep 20, 2010 7:19 am
Mon Oct 18, 2004 9:53 am
Basildon, Essex
Hi guys.
I beleive I have a metro steering rack. The one of the track rod ends died. So decided to replace them.
I was after a part QR1823S. But was given QR1420S as this was it's replacement. It is a very sloppy fit on the rack threads.
Is there imperial and metric thread sizes on different metro track rod ends?
Seat 1.8T, 550 genesis injectors, T28 turbo from a Nissan Pulsar, MBE engine managment, Jabba baffled sump.
Rover uprated PG1 box and Helix 6 paddle clutch kit. Custom 3" exhaust from Zorstec. Non CAT.
Mustang Chargecooler.
 Post subject: Re: Needs some help with Metro track rod end parts
PostPosted: Mon Sep 20, 2010 1:13 pm
possibly between austin metro and rover metro,
Im sure I had troubles, but hey this was 1998 so im hazy
PostPosted: Mon Sep 20, 2010 2:19 pm
Your first part number is from a mini, and the one your replacing it with is from a marina.
PostPosted: Mon Sep 20, 2010 2:22 pm
close then
PostPosted: Mon Sep 20, 2010 2:23 pm
Actually , first one is used on metro aswell.
So it appears your replacement is wrong ?
PostPosted: Mon Sep 20, 2010 3:44 pm
Metro, Marina and Mini all used QR1823S.
PostPosted: Mon Sep 20, 2010 4:26 pm
Basildon, Essex
I was told I needed QR1823S. Are QR1823S & QR1420S the same part? As the QR1420S one seems wrong.
PostPosted: Tue Sep 21, 2010 8:26 am
Basildon, Essex
Can someone check the part numbers for metro 80-90 &90-95 and see if they are two different part numbers?
Righto. Found a couple of things.
QH only has one part number listed for all metro's, QR1823S.
But first line has two:
80-90
http://www.firstline.co.uk/op3/f_ste...%20Rover&mmeid[0]=3736&mmeid[1]=3737&model=Metro&variant=-&subvariant=(1980-90)&engine=&product=Steering&var_desc[0]=3736__3996&var_desc[1]=3737__3997
90-95
http://www.firstline.co.uk/op3/f_ste...oduct=Steering
The difference being, the earlier metro ones are imperial, the later metic as per John's post above.
I've guessing I have the wrong firstline part.
