It is currently Wed May 23, 2018 1:46 pm
 Rover coupe - rear lower arm pivot bolts
 Post subject: Rover coupe - rear lower arm pivot bolts
PostPosted: Tue Jan 04, 2011 3:53 pm
Events & Area Rep
Wed May 14, 2003 1:08 pm
Northern Ireland
Would anyone have the part number for rear suspension pivot bolts? These are the ones that bolt the lower arms to the rear subframe?
I have limited access and need to put an order in with Rimmer so any assistance is greatly appreciated.
 Post subject: Re: Rover coupe - rear lower arm pivot bolts
PostPosted: Tue Jan 04, 2011 4:18 pm
Thu Sep 11, 2003 5:00 pm
DTEC - Mpumalanga, South Africa
I'll have a root in my bolts tub if you like Daz, I *might* have a couple I can bung in your parcel
Edit: Fail, I gave them all to Tom.
1994 220 GSi Turbo - Gone after 7 years but never forgotten.
2001 Peugeot 306 HDi - 1999 Peugeot 306 Rallye Supercharged - 2002 TVR Cerbera 4.5 V8 LW
PostPosted: Tue Jan 04, 2011 5:11 pm
Events & Area Rep
Northern Ireland
Mine haven't snapped *thankfully* but thought I'd change them since I'm replacing a couple of snapped bolts on the lower control arm.
PostPosted: Tue Jan 04, 2011 5:40 pm
RYG10031 :D
PostPosted: Tue Jan 04, 2011 7:46 pm
Mon Mar 12, 2007 5:48 pm
Oxfordshire
They're the same as the rear shock-lower arm bolts, as well as the trailing arm-lower arm bolts, and also the front lower arm pivot bolts and probably the same as a few others in case you didn't know.
>>>Spec thread<<<
