It is currently Fri Jun 22, 2018 7:47 pm
Reply to topic  [ 13 posts ]
 where to obtain a copy of Rave?
 Post subject: where to obtain a copy of Rave?
PostPosted: Tue Oct 02, 2012 12:47 pm
Mon Apr 16, 2007 9:49 am
west mids
ive lasted since 2007 without it but i really could do with some wiring diagrams!
does it cover the facelift ZS (diesel)?
also, does it cover the mk1 820 turbo (tickford)?
2003 Monogram Rover 45 Conni' 2.0 Turbo
 Post subject: Re: where to obtain a copy of Rave?
PostPosted: Tue Oct 02, 2012 1:35 pm
http://www.mgrover-online.com/
PostPosted: Tue Oct 02, 2012 1:42 pm
Good link :thumbup:
PostPosted: Tue Oct 02, 2012 1:43 pm
Sure this is run by KEVIN from here, support Admin, not so frequent a visitor these days,but was in the past
PostPosted: Tue Oct 02, 2012 9:29 pm
Unfortunately those versions of RAVE don't cover any 800 before 1996
PostPosted: Wed Oct 03, 2012 12:05 am
Mon Dec 27, 2004 11:17 pm
At the bridge, with Horatius.
The Haynes manual for the 820 (1988-1995) has some pretty decent wiring diagrams. The newer book may go later than 1995 but I bought mine when I got my first 800 many moons ago.
Stella now gone, Ruby is my baby now.
For your photography needs, try
http://www.freelancephotographic.net
PostPosted: Wed Oct 03, 2012 12:13 pm
west mids
cheers people - i have a copy on order :)
Im adding a DIY turbo controller to my ZS and wont to slice into an wires inside the cabin ideally rather than engine bay and would be handy to see where the TPS goes.
Ref the tickford - ah right, im sure i have an 800 haynes from when i had a 220 turbo - needed info on the T16 at the time, best find where it is!
PostPosted: Wed Oct 03, 2012 12:18 pm
TPS wires go straight from ECU to TPS.
PostPosted: Wed Oct 03, 2012 2:50 pm
west mids
it seems that the TPS loom goes back inside the big grommet under coolant reservoir - im guessing it comes back outthe passenger side grommet -to- ECU?
PostPosted: Wed Oct 03, 2012 3:28 pm
Rave doesnt list a TPS connection for an MG ZS TD ?
Looks as though it does it from the throttle pedal ?
PostPosted: Wed Oct 03, 2012 5:01 pm
west mids
ah well lol cheers for investigating :thumbup:
its dead weird mate - the throttle cable goes to the TPS in enginebay!! then its all elec from there - rover's version of drive by wire
ignore my DIY cruise control actuator :P
PostPosted: Wed Oct 03, 2012 9:50 pm
I don't think that's a sensor at all. That's a throttle switch. Only the pedal is used to sense the throttle position.
I can help with giving you the info on that if you think it can be used.
PostPosted: Thu Oct 04, 2012 12:02 am
The diesels are drive by wire. That is the TPS and it goes back to the ECU (there is no other input to tell the car to go faster when you want to otherwise!). They have been known to give issues on some models (wires chafe inside the protective sleeving giving no throttle response when driving in wet weather!)
