It is currently Sun Jul 22, 2018 9:33 pm
Reply to topic  [ 15 posts ]
 Fix it day - Tamworth
 Post subject: Fix it day - Tamworth
PostPosted: Sun Apr 07, 2013 3:33 pm
Sun Oct 29, 2006 11:48 pm
Tamworth, Staffs
Anyone up for a fix it day in Tamworth early may?
The TF (in my sig photo below) has been sitting for a while now since the cam spun out and destroyed the head.
It sat for quite a while after that, 2 heads later (first one was awful) it ran again.
I was starting it frequently to keep it running.
Fast forward a year or so and I had it trailered to where it is now, again I started it every now and again but during the past 3 or 4 months, life has got in the way.
It's sitting there in a sorry state, it needs some paintwork where some ar5e keyed it, the brakes are going to be seized solid, I dare say some bushes will need changing too and an oil and filter/coolant change.
But. The biggest problem is, I tried to start it the other day and all it does it spins. Last time it was started it fired right up, very tappety but it started and ran. It had been tappety since the head was changed.
I've lost motivation to fix it, I rarely get much time so by the time I've done one job another needs doing. If I can get 1 or 2 people to help me with what needs doing I think it could finally get sorted.
It could be as simple as a starter motor to get it running, although I have considered dropping another lump in there to have done with it. Shame because the car has only done 40k since new. It's the 1.6 MEMS 3 k series that's in there.
I need to get it done soon, the mrs has been diagnosed with an illness so our living standards is costing a fortune, she can't work anymore due to this illness and also that we have a 2 year old, we also need to move to a different house and the only way to have a chance of doing this is to get this car sorted so it can go to the paint shop and get sold. Will be a sad day but family comes first!
I have a week off work at the end of April/beginning of may so it would be an ideal time to try to get something done, is anyone local up for spending the day helping me out with it?
Cheers for reading
Dan
Custom Cut & Printed Vinyl Decals
MG/Rover key fob coding, remote coding available
Security matching of 5AS&ECU for MEMS 1.6&1.9
Immobiliser removal options
Flip keys!
 Post subject: Re: Fix it day - Tamworth
PostPosted: Wed May 01, 2013 1:03 am
I hope you get the motor sorted. :)
PostPosted: Wed May 01, 2013 6:44 am
Starter feeling sorry for itself?
If this had been the weekend of pol the scottish lads would have been there in a shot dan
Good luck!
Plenty rover gurus in the midlands !
PostPosted: Wed May 01, 2013 8:05 am
Tamworth, Staffs
More than likely Greg. Posted this a month ago so looks like its just me.
Flip keys!
PostPosted: Wed May 01, 2013 8:11 am
thats a shame
sorry cant be of any help!
PostPosted: Wed May 01, 2013 8:57 am
Tamworth, Staffs
Your not exactly local :lol:
Was going to do a bit on it the other day but it rained all day and I've been busy since. That's the way it goes. Every intention to do it but finding the time to actually do it is difficult.
Flip keys!
PostPosted: Wed May 01, 2013 10:17 am
When you say it spins but won't start,do you mean the engine turns but won't fire? If so it's not the starter motor as that is turning the engine. Which leaves Fuel or spark. Unleaded does go off so if the fuel is old and there is fuel pressure at the inlet manifold it might be worth puting some fresh in. You could try jury rigging a can and hose to gravity feed the manifold if the spark is ok just to see if it will run.
PostPosted: Wed May 01, 2013 10:35 am
Sun Sep 02, 2007 3:24 pm
Swindon, Wilts
I know this feeling! !! :cry:
I feel the need................. the need to boost!
PostPosted: Wed May 01, 2013 11:57 am
Tamworth, Staffs
No, as in the starter makes a noise but doesn't turn the engine. Not a normal starter motor noise either. Going to whip it off and connect it straight to a battery to see what it's doing.
Flip keys!
PostPosted: Wed May 01, 2013 12:44 pm
Check you can turn the engine too. Just in case.
PostPosted: Wed May 01, 2013 1:22 pm
Tamworth, Staffs
That will be the first thing I do.
Been sitting so long I can't remember the last thing I did!
Flip keys!
PostPosted: Fri May 03, 2013 5:49 pm
Mon Mar 12, 2007 5:48 pm
Oxfordshire
Check all the cables and connections to the starter, earths as well. Does the engine crank over by hand ok?
>>>Spec thread<<<
PostPosted: Fri May 03, 2013 6:09 pm
Tamworth, Staffs
Got it started yesterday, needs the tappets changing though, very very noisy and I have a set of good tappets from the other head. Just need to find time to pull the cambelt off to do it now!
Some Pektron issues to sort out too, just what I don't need!
Flip keys!
PostPosted: Sat Jan 04, 2014 11:08 am
Sat Apr 01, 2006 7:41 pm
Ill do a bit with ya if you wanna get it over to mine :thumbup:
scratch that, just seen how old the thread is.
did you end up fixing it dan?
Of all the things i've lost in my life, i miss my mind the most. Ozzy
PostPosted: Sat Jan 04, 2014 7:40 pm
Tamworth, Staffs
Half and half really Gaz then ended up moving house so it had to go in a hurry cus of space issues. Ended up just selling it as it was.
Flip keys!
