It is currently Sat Feb 24, 2018 1:02 pm
Reply to topic  [ 13 posts ]
 pg1 longer 5th gear
 Post subject: pg1 longer 5th gear
PostPosted: Sun Jan 11, 2015 11:46 pm
Tue Sep 17, 2013 3:09 pm
hello all i am just wondering is it possiable to make the 5th gear longer for more top speed?
 Post subject: Re: pg1 longer 5th gear
PostPosted: Mon Jan 12, 2015 1:44 pm
Only if you currently have an excess of power such that you can hit the redline in fifth gear. Otherwise you will probably end up with a reduced top speed.
PostPosted: Mon Jan 12, 2015 1:48 pm
^^^^ This
PostPosted: Mon Jan 12, 2015 8:00 pm
Wed Feb 16, 2011 8:59 pm
Beroun, Czech Republic
I've been interested in it too - on my 420SDi, but I need it for more engine efficiency and lower revs on highway... :whistle:
MG ZS 180 T16 Turbo
620Ti (evo IX turbo, recaro, evo fuel pump, FMIC, sard FPR, OMP steering wheel, 18" SL-corse on SA30)
420SDi (straight flow exh.,EGR-off)
PostPosted: Mon Jan 12, 2015 8:57 pm
Fri Oct 12, 2007 11:51 pm
Darlington NORTH EAST
Normally you will change the final drive.
Which involes fitting the crownwheel and the output shaft (as the pinion is part of it)
Im wondering if a gear from the primary shaft could be put into the output shaft?
Otherwise it might be custom gears.
Perhaps someone else will be more clear :lol:
PostPosted: Mon Jan 12, 2015 9:47 pm
Fri Aug 30, 2013 11:46 pm
Regarding the comment about a custom 5th gear would that be few hundred £ or more like , £1000,s
PostPosted: Mon Jan 12, 2015 9:50 pm
Are you bothered about all of the gears being higher?
PostPosted: Mon Jan 12, 2015 11:43 pm
Yes you can fit a higher final drive. It has been done but is a lot of work so most people won't go this route. (you'd not want to do this for a track car!)
PostPosted: Tue Jan 13, 2015 9:11 pm
any more details etv?
PostPosted: Wed Jan 14, 2015 1:15 am
It isn't a small amount of work!. Certain versions of the freelander have a higher final drive, so you can recover this from a freelander box and build yourself a slightly longer final drive. I think they have the "7" ratio set in the diesels but please check first! Whereas the L series cars have the "4" and "6" final drives.
PostPosted: Sun Jan 08, 2017 12:10 pm
a mate has done it to his improves final drive and drops rpm by around 500rpm so a good mod to do:)
PostPosted: Thu Jan 12, 2017 7:13 pm
Sat Apr 19, 2003 12:49 pm
In my garage
I have a diesel 5th gear in my PG1, the rest of the gears are a mix from different boxes to get an even spread as close to the 5th as possible but it is still a larger than normal drop in rpm going from 4th to 5th but I can use it for cruising at 50mph +, it is great at 70mph. When the car was mapped it was getting over 170 on the rolling road.
Originally built the gearbox for top speed but never got chance to try it out.
Rover 820
PostPosted: Sun Feb 05, 2017 5:23 pm
why not just use a derv box and final drive for a freelander.?
