It is currently Wed Jan 17, 2018 12:27 am
Reply to topic  [ 7 posts ]
 zs derv buzzing??
 Post subject: zs derv buzzing??
PostPosted: Wed Jan 28, 2015 7:22 pm
Wed Jun 10, 2009 10:01 pm
Banbury, Midlands
The fuel pump on my zs has started buzzing, is this an early sign of fuel pump problems or timing solonoid?
got no warning lights or anything, still drives ok,
Does however misfire sometimes on cold start, not very often tho
Current rover status
Rover BRM
Rover 220 coupe turbo currently in a million pieces
 Post subject: Re: zs derv buzzing??
PostPosted: Wed Jan 28, 2015 10:20 pm
Are you sure it is the fuel pump?
The EGR valve commonly buzzes when active and although annoying can be regarded as normal.
PostPosted: Wed Jan 28, 2015 10:59 pm
Mon Feb 04, 2008 10:38 pm
timing solenoid on these will give a buzzing but unlike the sdi on msa11 management should shut off when the engines not running even with ignition on
DieselPowered Engine Tuning
Producing the highest power diesel rovers you're likely to see :D
PostPosted: Wed Jan 28, 2015 11:31 pm
Banbury, Midlands
So I could be being paranoid then :lol:
Rover BRM
PostPosted: Wed Jan 28, 2015 11:57 pm
Just because you are paranoid, it doesn't mean everyone isn't actually out to get you :p
PostPosted: Sun Feb 01, 2015 8:05 pm
Start to worry when it doesn't buzz!
ETV, welcome to the 'everyones out to get me' club. Best cure is not to deny it but to justify it
PostPosted: Mon Feb 02, 2015 10:57 am
Banbury, Midlands
That's good to know :lol:
Rover BRM
Users browsing this forum: Yahoo [Bot] and 1 guest
