It is currently Sat Feb 24, 2018 12:50 pm
Reply to topic  [ 10 posts ]
 ZR TD problems
 Post subject: ZR TD problems
PostPosted: Mon Jul 13, 2015 7:16 pm
Wed Mar 21, 2007 5:06 pm
N.Ireland
Well folks bought a wee high miler ZR for work. Problems I have are:
When left sitting it will take an age to start from cold near running down the battery down. Once started once it starts fine again.
Where do i start to look for problems? Heater plugs?
Priming the wee bulb on the fuel line makes no difference either.
MG ZR 2.1 Turbo
MG ZS 180 MK2
 Post subject: Re: ZR TD problems
PostPosted: Mon Jul 13, 2015 8:31 pm
Check fuel pump belt timing if pumping the priming bulb till it goes hard before starting makes no difference.
PostPosted: Mon Jul 13, 2015 9:03 pm
N.Ireland
Sorry for my ignorance but how do I check that lol
MG ZR 2.1 Turbo
MG ZS 180 MK2
PostPosted: Mon Jul 13, 2015 9:38 pm
Insert locking pin into flywheel 6.5-6.75mm
Insert locking pin into fuel pump pulley hole (after removing belt cover). If it doesn't go in then the timing isn't right.
PostPosted: Mon Jul 13, 2015 10:19 pm
N.Ireland
Thanks E T V must get it looked during the week.
I'm more of a petrol man lol
T16 ZR and V6 ZS lol
MG ZR 2.1 Turbo
MG ZS 180 MK2
PostPosted: Mon Jul 13, 2015 10:53 pm
Same timing pin for the crank fits the T series too just T is on the front of the bell housing and L series is on the back of the housing. :D
PostPosted: Mon Jul 13, 2015 11:15 pm
Sat Mar 05, 2011 1:01 am
leeds
Hi there my L series sometimes took a while to start I found that charging the battery up gave it that extra kick to bring it to life, try some injector cleaner and a big battery as I'm sure they take some power to wind the machine over.
PostPosted: Tue Jul 14, 2015 10:06 am
In summer it should spring into life instantly. If not then the usual fault is the fuel pump timing is wrong (its easy to get wrong and the only symptom is poor cold starting).
PostPosted: Tue Jul 14, 2015 12:38 pm
N.Ireland
So pulled the cover off the fuel pump belt. Belt is deffo slack so going to lift a new one today.
Is this a diy job to change or should I leave it to the pros?
Any guides?
MG ZR 2.1 Turbo
MG ZS 180 MK2
PostPosted: Tue Jul 14, 2015 1:56 pm
Perfectly DIY-able with the following notes
1. You NEED timing pins. Drill bits will also work fine. 6.5 or better 17/64 for the crank (same as T series), and I think it is 9.5mm for the fuel pump. (you may find you need to lock the fuel pump first and then remove the belt and move the crank to fit the crank pin in place if the timing is wrong).
2. You must loosen the cam vernier adjustment pulley (4 off) before tensioning the belt
3. Tension the new belt
4. LAST of all re-tighten the cam vernier adjustment bolts.
Some manuals get this order wrong and then the pump timing will be out. If the pump timing is even half a tooth out then the car will be difficult to start when cold.
