It is currently Tue Jun 19, 2018 12:16 am
Reply to topic  [ 7 posts ]
 420 non intercooled to intercooled?
 Post subject: 420 non intercooled to intercooled?
PostPosted: Thu Jan 28, 2016 1:27 am
Fri Jan 16, 2009 1:42 am
whats involved in fitting the intercooler from later models to the Early models? will it all just bolt in?
the car in question has a mechanical injection pump and a throttle cable about 10 ft long! from what ive seen of the later cars the boost pipe runs across the front of the engine pretty much where the throttle cable runs on early one? what do people do to get round that?
so far im running 18psi with the pump fiddled with but its actually pretty noticeable when the engine gets hot that it doesn't have the same enthusiasm as when its cold.
Rover 220 turbo Coupe in nightfire red gone, but her heart lives on in a ZR now :(
Austin Allegro 1.3 HLS, 1275 T3 Turbo 7 pounds of boost! :D
Austin Maxi 1750 L in Carmine
Rover420D decat egr delete @18psi
 Post subject: Re: 420 non intercooled to intercooled?
PostPosted: Thu Jan 28, 2016 9:18 am
you'll notice it gets hot when your pistons genade. :lol:
Well covered topic that if you are on stock pistons 12 psi is where you should be and as you haven't mentioned that i'll put that part first.
As for FMIC some fabrication is always required but any universal kit will fit. Stay away from jubilee clips and use proper mikalor clamps.
PostPosted: Thu Jan 28, 2016 11:03 am
12 psi? on an L series diesel? i thought they ran 15psi standard and at least 17psi on the later intercooled engines...?
on the same pistons!
PostPosted: Thu Jan 28, 2016 11:35 am
Sorry, i saw nothing about it being a diesel.
Just noticed the group :facepalm:
PostPosted: Thu Jan 28, 2016 7:30 pm
So does any one have a guide or pictures of one installed with a mechanical injection pump? :?
PostPosted: Fri Jan 29, 2016 12:47 am
Think I've replied to this on the .org forum.
PostPosted: Fri Feb 05, 2016 5:27 pm
Fri Jan 09, 2004 11:42 am
devon
Done this, no pics but easy enough to do. You need inlet manifold and all intercooler pipes and the cooler. Radiator is the same, you may have to extend the intake air temp sensor as its in the crossover pipe on the di's and in the manifold on the d's.
BUILDER OF THE FIRST 2.2. dohc vtec Rover 600 ever built.
2.2 Vtec Rover 600 (sold :-( )
Rover 200 vi(now full T16 225bhp) (ours)
Mg zs180 Black (wifes)
Mk2 Rover 45 113se td (my Toy)
