It is currently Sat Jul 21, 2018 8:31 pm
Reply to topic  [ 2 posts ]
 Rover 75 diesel engine vibration
 Post subject: Rover 75 diesel engine vibration
PostPosted: Fri Dec 23, 2016 8:00 am
Fri Apr 15, 2016 9:39 am
My 75 diesel vibrates annoyingly at idle. It feels like the revs were a bit low but it does not cure even if you press the gas pedal slightly. There is only 136 k on the clock so the engine should still be in a good condition. There is a new clutch but the DMF is still the original. Sometimes there is also a slight judder when taking off so could it be the DMF even if the garage said it was still ok? Could the lower engine mount give this kind of symptoms?
 Post subject: Re: Rover 75 diesel engine vibration
PostPosted: Fri Dec 23, 2016 11:16 am
engine mounts is defo where id be looking
