It is currently Mon Feb 19, 2018 4:41 pm
 K-series Turbo Engine Plus Ancillaries
 Post subject: K-series Turbo Engine Plus Ancillaries
PostPosted: Sun Jul 31, 2016 3:54 pm
Mon May 13, 2013 10:02 pm
Cheshire
K-series 1.8 Turbo Engine Plus Ancillaries
Difficult to gauge value as a rebuild is required. Engine had head gasket and turbo failure.
Complete list of items
K-series turbo bottom end complete with correct turbo pistons (160 stamp and shorter rods) and oil drain point. Liners are in good condition with original honing marks still evident. Block is in good condition and had no external leaks. Stripped down to component parts.
K-series cylinder head complete with inlet manifold, injectors, fpr, throttle body, sprockets, sensors. Carrier and cams removed from head for inspection.
K-series turbo exhaust manifold.
K-series turbo down pipe.
Standard Rover 75 K-series Garrett GT2052LS turbo. The turbo will require a build or replacement as there is play in the turbine shaft.
Complete Rover 75 engine wiring loom plus engine bay fuse box and ECU (ecu no use on ZR/ZS).
Heat shield, , aircon pump, alternator/aircon housing + tensioners.
Turbo pipe work, fittings, and intercooler.
Collection of various bolts and clips for engine and ancillaries.
Some coolant hoses and fittings.
Also if being used for ZR conversion I have ZR 160 gearbox (G gearset) and flywheel and driveshafts.
Rover 200 BRM Turbo
MG Maestro Turbo
 Post subject: Re: K-series Turbo Engine Plus Ancillaries
PostPosted: Sun Jul 31, 2016 3:59 pm
metro boys on fb would be all over this
PostPosted: Sun Jul 31, 2016 4:00 pm
Cheshire
I'm not on Facebook :)
Rover 200 BRM Turbo
MG Maestro Turbo
PostPosted: Sun Jul 31, 2016 5:01 pm
Good time to start :lol:
