It is currently Mon Jul 16, 2018 7:56 am
Reply to topic  [ 13 posts ]
 Big Valve Kit - T16
 Post subject: Big Valve Kit - T16
PostPosted: Fri Feb 14, 2014 3:06 pm
Hi there,
We are just commissioning a new batch of big valves for the T16 if anybody is interested?
We buy these in big batches of 75 inlet and 75 exhaust valves, so will have plenty :)
They are NOT Ford valves modified to fit, but are instead a properly designed valve with the correct dimensions and shapes to allow optimum flow in and out of the head.
No bodges here!
30.5mm Exhaust and 34.0mm inlet.
This is the most appropriate size for the T series :)
Plasma Nitrided for extra wear resistance and heat capabilities.
£435 inc vat per set of 16.
Options:
Guides - POA
Double valve springs and caps - £300
 Post subject: Re: Big Valve Kit - T16
PostPosted: Fri Feb 14, 2014 6:39 pm
Can you elaborate a little more on the possible benefits, along with other items these may give?
PostPosted: Fri Feb 14, 2014 6:50 pm
A larger valve will allow more air into and out of the engine, allowing more power.
Not worth it at all if you are looking at sub 300hp figures.
That said, the valves are MUCH stronger than OE and flow so much better.
PostPosted: Fri Feb 14, 2014 8:20 pm
Wed Dec 31, 2008 6:33 pm
Rainham, Kent
Damn you Grant... :x
Rough guess-timate... How much would a good shop charge to make these fit? Can PM me if you rather :)
-Lotus Elise 111
-2001 MG ZS MK1 Turbo
You Can't Spell Dangerous Without Dan ;)
PostPosted: Fri Feb 14, 2014 8:27 pm
Sun Nov 18, 2012 2:33 pm
would be interested on rough fitting price also :wink:
PostPosted: Fri Feb 14, 2014 8:37 pm
I so want :cry: but lack of funds and i still need to order the external trigger wheel set up.... fecking mortgages and losing my job shortly.....
PostPosted: Fri Feb 14, 2014 10:36 pm
Sun Apr 05, 2009 9:46 pm
Cambridge
You can make around 400 on standard valves with a ported head so if you are wanting to go 450+ then it would be a good idea
PostPosted: Sat Feb 15, 2014 12:42 am
Tricky one.
If you were starting with a stock, unported head... I'd say you are looking at £800 for labour to port and sort the valves.
PostPosted: Sat Feb 15, 2014 12:57 am
Rainham, Kent
Hmm... intriguing... can certainly see where all the cost is for the stroker kit head work ;)
-Lotus Elise 111
PostPosted: Mon Jun 09, 2014 2:07 pm
Valves here this week finally!
Buy once, buy the best!
PostPosted: Thu May 31, 2018 8:33 pm
Fri Mar 23, 2018 9:03 am
I'm interested in a set of those... What other parts would be needed to match? and what changes should the cylinder head go under?
Any other parts you may suggest?
cranks, rods, pistons? I want to know more about the whole lot please..
Thank you for your time.
Best regards..
PostPosted: Thu May 31, 2018 8:54 pm
Sat Mar 05, 2011 1:01 am
leeds
Bloody hell be lucky if any of them are still around! Talk about digging up a old thread! Last post only 4 years ago! You would be best contacting Grant at GBE direct on there website GBEnterprises
PostPosted: Fri Jun 01, 2018 12:41 pm
Usually got the valve kits in stock.
Gimme a call on 01278 287346 or email sales@gb-ent.com
