It is currently Mon Jul 16, 2018 9:32 pm
 Gizzmo IBC-R V2 Slim Boost Controller
 Post subject: Gizzmo IBC-R V2 Slim Boost Controller
PostPosted: Tue Apr 28, 2015 11:34 am
Hi Guys!
The NEW Gizzmo IBC-R is now in stock!
Incorporating RPM-Dependant boost control, we have been able to get a STANDARD Mitsubishi EVO 5 (with a remap) to hold a stable and solid 19.5psi from when it was able to make boost, right up to the rev limiter!
With a flat duty level on self-learn mode (closed loop), the best that can be achieved is 19.5psi dropping to 17.5psi.
With self-learn off (open loop), and a flat 60% duty it pulls 19.5psi, dropping to 15.8psi.
This is an indication of how effective RPM-Dependancy is!
There are VERY few controllers on the market that are able to do this, and none for under £250!
Other features include:
-Slimline Case, only 57x26mm and an incredible 18mm thick, with NO Separate Control Box!
-Normal, simple 3 wire installation (Power, Ground and RPM input)
-Solenoid just plugs into the loom
-Built in Shift Light
-SIX boost levels of your choosing
-Overboost cut out, which not only warns you, but cuts boost back to ZERO duty – ie disables the solenoid
RRP is £259.00 inc VAT.
INTRODUCTORY PRICING Until May 30th
RRP is £249.00 inc VAT.
http://gb-ent.com/index.php?route=product/product&product_id=6612
