It is currently Fri Mar 23, 2018 12:33 am
 Gizzmo Tach Recall 2 Shift Light
 Post subject: Gizzmo Tach Recall 2 Shift Light
PostPosted: Tue Aug 25, 2015 12:04 pm
Gizzmo's Tach Recall 2 Shiftlight is a unique dual stage shiftlight, which incorporates the features of many aftermarket tachometers/rev counters into most any stock OEM rev counters.
The Gizzmo Tach Recall Shiftlight allows any rev counter to have a peak rpm saved to memory which can be recalled and displayed at any one time, the peak rpm reached during the current trip is available for recall.
Fully adjustable: 500-16000 rpm Simple three button operation
Peak RPM Memories recalled via tachometer/rev counter
Shift points set via tachometer
The shift stages are set using the three-button configuration to move the tachometer's rpm needle to the desired revs for each individual stage. Upon the ignition being switched on the unit will display peak saved rpm, second stage shiftlight setting and then first stage shiftlight setting, by indicating the rpm position on the tachometer, and flashing the corresponding LED's.
Can also be used in "simple" mode if you wish to have a basic shift light that doesn't move the rev counter.
An amazing product that has to be seen and used to be truly believed.
In stock now at £89.00
