It is currently Tue Sep 07, 2010 5:14 am
Reply to topic  [ 11 posts ]
 Stainless steel battery trays
 Post subject: Stainless steel battery trays
PostPosted: Wed Jun 23, 2010 5:17 pm
Ok, seeing as my main thread was getting cluttered ive decided to put each item into its own post so I can keep things organised.
Ok.
1989 - 1995 Rover 200/400 stainless steel battery trays
Supplied as a direct replacement for the original, supplied with 6 s/s caphead allen head bolts, the clamp and bolt.
A few guys have bought one off me and had no complaints. Easy. Although the above was my prototype and I hadn't welded the corners up.
Fitted pic
Im looking at £26 posted for this item
Engine dress up bolt kits, Stainless battery trays Rear upper strut braces heatshields, spark plug covers. Anything made - pm me or see general trade thread.
:whistle: :w00t: :whistle: :whistle: :w00t: :whistle:
 Post subject: Re: Stainless steel battery trays
PostPosted: Fri Jul 02, 2010 5:09 pm
weekend bump 8)
PostPosted: Mon Jul 05, 2010 4:31 pm
Tue Oct 28, 2008 6:37 pm
Erith Near Dartford
sorry if this has been asked before but will these fit a ZR?
PostPosted: Mon Jul 05, 2010 4:54 pm
you have pm
:mrcool:
PostPosted: Thu Jul 08, 2010 3:57 pm
bump to the top
Had a few requests for maestro battery trays too :wink:
PostPosted: Thu Jul 08, 2010 9:32 pm
Sheffield
Yes I've got to dig you a template out this weekend.
yes and clamp :D
PostPosted: Thu Jul 08, 2010 10:03 pm
Sheffield
No worries.
Whereabouts are you? Just wondering if it was easier to give a whole car to you :)
I need an exhaust too but dunno if that is your area or not.
PostPosted: Tue Jul 20, 2010 4:19 am
Sun Apr 04, 2010 6:37 pm
Dumbarton (Glasgow)
vinny, thinking about going for a bat. to boot conversion on my turbo coupe , i assume these would work ok mounted in the boot also?
has this been tried with one? i assume as its the same design as the original there should be no problems with it, but thought i would ask.
If It Can't Be Fixed With Cable Ties Or Duct Tape, Then It Can't Be Fixed!!!!!
PostPosted: Tue Jul 20, 2010 5:39 am
hey maye would work fine.
Ive been thinking about doing the same!
It still has the two clamping points for battery, and you have 6 holes to choose from to mount to the chassis, if you wanted extra tabs on the sides for other bolts, no problems
PostPosted: Tue Jul 20, 2010 9:55 pm
Sheffield
Certainly an idea.
Can you PM me an address to send this maestro tray to you to have a look at.
