It is currently Thu Sep 09, 2010 7:16 pm
Reply to topic  [ 3 posts ]
 Rover 200/400 stainless underbonnet bolt kit
 Post subject: Rover 200/400 stainless underbonnet bolt kit
PostPosted: Wed Jun 23, 2010 5:24 pm
! STRIKE 2 !
The Rover 200/400 engine dress up kit
Specifically designed for the 2.0 Turbo models, a 114 piece kit, containing s/s caphead bolts, washers etc to replace the following bolts
Headlights
Radiator support brackets (upper)
Radiator support brackets (lower)
Fan to radiator frame
Bonnet catch to body
Rocker cover bolts (visible 11) please tell me if you want the other 12 hidden normally by the lead/spark plug cover ( add £2.50 )
Spark plug cover
Inlet manifold to engine
Front coolant pipe
Power steering bracket
Wiper motor
Accelerator cable
Washer fluid pipe bracket
Fuel filler bracket
Coolant reservoir bottle
Screenwash bottle
Fan relay box
Comes with instructions but is pretty easy , replace the rusty bolts with shiny stainless steel ones
The kit will fit k series rover's but the rocker bolts etc *may* be different. I can supply smaller kits, until I get up to speed for a specific k-series kit
Looking for £13 posted for this kit kit 1
If you want the bolts that are normally covered by the lead/spark plug cover aswell £15.50 posted - kit 2
If you want the wing bolts and bonnet hinge bolts on top of the above £17 posted. - kit 3
See my other advert for the honda derived d-series engine bolt kit
Engine dress up bolt kits, Stainless battery trays Rear upper strut braces heatshields, spark plug covers. Anything made - pm me or see general trade thread.
:whistle: :w00t: :whistle: :whistle: :w00t: :whistle:
 Post subject: Re: Rover 200/400 stainless underbonnet bolt kit
PostPosted: Fri Jul 02, 2010 5:08 pm
! STRIKE 2 !
weekend bump
PostPosted: Thu Jul 08, 2010 3:57 pm
! STRIKE 2 !
To the top
Ive sold quite a few kits and can supply as many or as few bolts as you want
:w00t:
