It is currently Sat Jul 21, 2018 4:49 pm
Reply to topic  [ 115 posts ]  Go to page Previous  1, 2, 3, 4
 Steel Caged PG1 Gearbox Bearings and Seals
 Post subject: Re: Steel Caged PG1 Gearbox Bearings and Seals
PostPosted: Fri Jun 02, 2017 2:57 pm
Tue Apr 24, 2012 9:48 pm
Lifes highway
Does anyone know where I can get a steel caged 4/MJ28 from for a NASP gearbox ?
Or is the NASP kit still available ?
1993 220 NASP Coupe
PostPosted: Fri Jun 02, 2017 4:54 pm
Mon Oct 06, 2003 10:29 pm
Glorious, Gloucestershire
If that is the Input Shaft Bearing in the centre of the PG1 Gearbox Bell Housing I can supply a new one of those if you get stuck locally.
Premium quality steel caged.
Apparently ... in a parallel universe MGJohn drives ....wait for it..... A ..
B>>M>>W ....
Arrrrrggghhhhh.........Image......Arrrrrggghhhhh.........
PostPosted: Fri Jun 02, 2017 6:08 pm
Lifes highway
PM Sent.
1993 220 NASP Coupe
PostPosted: Mon Apr 02, 2018 7:31 pm
Tue Feb 07, 2017 6:11 pm
After a steel cage u spec 3/LJ28 and a RJ2024, anyone able to help messaged op but no reply.
PostPosted: Mon Apr 02, 2018 8:17 pm
I have a few steel caged premium grade PG1 Bearings new in their boxes. These include actual MG-Rover ones too. some are quite expensive and far from easy to obtain now.
Refresh my memory. Which bearings are they. Positions in PG1 Box etc. I may be able to help.
John.... Gotta keep these fine old cars moving ... :drive:
B>>M>>W ....
PostPosted: Tue Apr 03, 2018 7:06 am
Tue Sep 27, 2011 1:24 pm
Solihull
https://www.123bearing.co.uk
http://www.brt-bearings.com/location_redditch.html
2 places i got mine from
P.
PostPosted: Tue Apr 03, 2018 9:18 am
The lower (bell housing) main shaft RJ2024
The upper input shaft still cage 3/LJ28
Missing and input shaft and gear selector seal if you happen to have them to.
PostPosted: Tue Apr 03, 2018 1:45 pm
Just checked my store of new PG1 Bearings and I have a spare "UPRATE". This fits on top of the Input Shaft and locates in the upper PG1 casing ( not bellhousing )
There are two sizes of this bearing fitted into PG1s, the larger "UPRATE" version usually fitted to the Gearbox in the Rover Turbo Petrols to cater for the power increase. This image shows my spare steel caged one. Let me know if this is one of those you need. I thought I had the smaller Input Shaft Bearing which fits into the lower case ( bellhousing ) but, used my last a few weeks ago with another rebuild. This thread has reminded me to get some more of those. This one I can offer :~
B>>M>>W ....
PostPosted: Tue Apr 03, 2018 10:31 pm
Pm'd you, looks like what I need.
PostPosted: Mon Jun 04, 2018 5:34 pm
Fri Mar 23, 2018 9:03 am
Hello there,
I have a rover 620ti and want to fit in a whole new set of bearings because all gears have this niiiii noise. It's not too annoying but I fear it's going to end up ruining the gearbox. I dont know where to look for the sticker for the gearbox code and was also wondering if it would be better to fit roller bearings on both sides of the TORSEN DIFFERENTIAL.
BTW, I thought that the 220 turbo and the 620ti shared identical engine and gearbox and frond axles...¿?
regards
Norbert
