It is currently Sun Apr 22, 2018 12:08 am
 Millers Oils Nanodrive Engine Oils, Pre-Order HERE
 Post subject: Millers Oils Nanodrive Engine Oils, Pre-Order HERE
PostPosted: Wed Feb 22, 2012 3:22 pm
Fri Sep 24, 2004 9:31 pm
South West
Developed by Millers Oils highly acclaimed team who are responsible for the highly successful NT Gear Oils that won World Motorsport Award for best new product in 2009, the Nanodrive engine oils are specifically targeted to release power through friction reduction but also maximise wear protection. The Nanodrive formulation reduces friction by the use of spherical nanoparticle structures within the oil that actively fill rough metallic surfaces making a “tribofilm”, which means an ultra smooth surface. The groundbreaking formulation reduces load friction at extreme pressures even in stop start driving conditions, meaning less component wear and increased power.
KNOW THE DIFFERENCE...
What is the difference between conventional Motorsport engine oils and the new Millers Nanodrive technology engine oils?
- Increased power output and performance
- Significantly reduced friction
- Reduced component wear ensures longer component life
- Reduced heat generation
- Improved reliability
- Improved energy efficiency
- Extends engine oil life and maintenance intervals
- Superior anti-friction & anti-wear characteristics
Millers Nanodrive CFS range can be used on track or fast road use.
Oilman
Use the code ROVER and get 10% Club Discount
oilman's website: http://www.opieoils.co.uk/ - register for news and offers
email: sales@opieoils.co.uk
phone: 01209 202944
 Post subject: Re: Millers Oils Nanodrive Engine Oils, Pre-Order HERE
PostPosted: Wed Feb 22, 2012 3:31 pm
Sun Mar 06, 2011 7:06 pm
bishops stortford
dont most of us need 10w 40? do you have any?
MG ZT CDTI daily runner
220 coupe turbo M reg brand new 620ti engine
Now run in, time to crank up the boost
rover T16 turbo possibly the best induction noise ever
PostPosted: Wed Feb 22, 2012 3:38 pm
South West
A 5w-40 will give better cold start protection than a 10w-40, so it's a better option.
Tim
phone: 01209 202944
PostPosted: Wed Feb 22, 2012 4:44 pm
bishops stortford
ok and there are no other side effects once its hot, is it as good when taking a beating for long periods of time, thanks.
PostPosted: Wed Feb 22, 2012 5:18 pm
South West
Hi
It will be fine when it's up to temp and as it's a top quality oil, it will happily deal with a beating.
Tim
phone: 01209 202944
