It is currently Mon Jan 22, 2018 11:37 am
Reply to topic  [ 30 posts ]
 Key Fob Coding, ECU Security Matching & Immobiliser Bypass
 Post subject: Key Fob Coding, ECU Security Matching & Immobiliser Bypass
PostPosted: Tue Apr 24, 2012 8:17 am
Sun Oct 29, 2006 11:48 pm
Tamworth, Staffs
Hi All,
We have just moved in to key fob coding to go with the mechanical repairs.
We are based in Tamworth and we do this part time, we can code you a new keyfob if you have a rover 100/200/400 (others available, please check). We can also do other makes and models, for example yesterday we coded a new fob to a Vauxhall Astra.
Our rates are rock bottom for the key fob coding business and if you supply your own fobs its even cheaper!
We have a pile of fobs for the rover system (5as system) so we are able to program these without delay.
Get in touch for a quote and see how much you can save.
Thanks for reading.
Custom Cut & Printed Vinyl Decals
MG/Rover key fob coding, remote coding available
Security matching of 5AS&ECU for MEMS 1.6&1.9
Immobiliser removal options
Flip keys!
 Post subject: Re: Key Fob Coding and Mechanical Repairs
PostPosted: Tue Apr 24, 2012 8:05 pm
Tamworth, Staffs
In addition to this, key fob coding prices start from just £30!
Flip keys!
PostPosted: Sat Apr 28, 2012 7:34 am
Tamworth, Staffs
Hi all,
Our bench rig is now up and running so we are now able to code new fobs to your 5as units sent through the post.
Very handy if you aren't near to us.
Its generally a 2 day turn around so as an example you send your 5as Monday, we get it Tuesday and send it back out and you get it Wednesday.
Dan.
Flip keys!
PostPosted: Mon Jun 25, 2012 9:23 am
Tamworth, Staffs
Who needs 5as fobs then? :) Get in touch for a quote for what you need.
Flip keys!
PostPosted: Tue Aug 07, 2012 8:21 pm
Tamworth, Staffs
£25 including return post for remote fob codes. Lucas 5as systems only unfortunately.
Send us your 5as unit and existing fob and we will return it all to you with an extra fob for £25 including next day delivery.
You can come to us if you are local too or we can come to you.
Flip keys!
PostPosted: Tue Aug 07, 2012 8:52 pm
Sun Sep 02, 2007 3:24 pm
Swindon, Wilts
Can u do new fob for freelander (think its a 27vt system). I can send ecu.
I feel the need................. the need to boost!
PostPosted: Tue Aug 07, 2012 10:05 pm
Tamworth, Staffs
Only the Lucas 2 button black square fobs mate that use the 5as.
Mainly 100, 200, 400, 25, 45 etc.
Don't think yours would work, sorry bud :(
Flip keys!
PostPosted: Wed Jan 02, 2013 12:15 pm
Tamworth, Staffs
Hi all,
I am now able to "remote code" new remotes/fobs to the lucas system.
Basically it would be a rover compatible fob, looks different to the usual black Lucas type, this comes with a pod. You plug the pod in to your car, wait for 1 minute and the fob is ready to use, it also keeps any fobs in the memory that are currently coded.
Then you have to return the pod to me, I need to have it back within one week of sending it you, I can extract your EKA code from the pod when I get it back which I will forward to you.
What happens is:
The Pod uses a completely different method to the usual diagnostic 'learn mode'.
It uses the fact that the 5AS (or 10AS etc) control unit can learn up to 4 remotes, but usually only has a maximum of 2 stored.
It identifies the first unused slot (usually number 3) and writes the new remote into that slot.
If you currently have 4 remotes coded or have had 4 in the past (lost etc) this will not work.
So existing remotes are kept.
When it writes the new remote in, it does this because it knows the serial number of the remote it comes with. The standard remotes don't come with this number so the rover compatible one must be used.
Also, we keep a note of the remote's ID. That way, if a customer subsequently loses their remote (and it has happened) we can supply its 'clone' without having to reprogram anything
This way is unfortunately more expensive and there is a deposit for the pod.
The cost is £55 for the whole thing, with a £20 deposit payable on top of that. As long as the pod gets back to me within 1 week of it being sent to you the £20 is refunded to you.
This is an ideal solution for anyone who doesn't live near to me and can't afford to be without the car if you posted me your 5as.
Also, for anyone having immobiliser trouble, if you have a MEMS ecu and 5as in your car, I can supply an immobilser module that will bypass the immobiliser and mimic a permanently disarmed immobiliser.
This requires a small black box to be fitted to the car and connected to various wires, this part must be done yourself. The box also needs security matching to your ECU so I would need the car/ECU here.
Flip keys!
PostPosted: Wed Jan 02, 2013 2:26 pm
Tamworth, Staffs
Normal coding if you bring the car to me is £20.
If you supply the fob it's £15, this also includes your EKA code.
If you want the EKA code changing to something more memorable to yourself, I can do that for an extra £5 on any of the prices above. Any 4 digit number excluding zero.
I can also fault code read most Rovers at the same time as coding the fobs.
Flip keys!
PostPosted: Sat Jan 05, 2013 4:59 pm
Sat Nov 01, 2008 11:26 pm
Just had a fob programmed and eka code read. Top service and great value thank you :thumbup:
1.8 VVC 1992 Mini 13.5 @ 101mph 163hp
2.0 T16 1998 Tomcat 13.7 @ 105mph 240hp est!
2.5 Kv6 1998 Tomcat 14.5 @ 98mph 174hp
1.6 1996 R100 Metro 15.3 @ 87mph 120hp - sold.
PostPosted: Sat Jan 05, 2013 5:00 pm
Tamworth, Staffs
Cheers for the feedback mate!
Flip keys!
PostPosted: Tue Jan 08, 2013 5:27 pm
Tamworth, Staffs
I've got a couple of people coming to my place in Tamworth on this coming Saturday 12th Jan to have Lucas fobs coded, anyone from here want to pop in too?
Low prices and quick service!
Flip keys!
PostPosted: Tue Jan 08, 2013 9:50 pm
Tue Apr 21, 2009 11:14 am
Keighley
My 220 coupe turbo has only one keyfob which is playing up and also deactivates immobiliser can you reecode a new one. What parts do you need ecu and fob im assuming. Price please feel free to pm me
Life Dosn't start until 20psi turbo boost
Never let a rover be under-estimated
PostPosted: Tue Jan 08, 2013 9:56 pm
Tamworth, Staffs
Pm'd!
Flip keys!
PostPosted: Mon Feb 11, 2013 10:09 am
Tamworth, Staffs
I will be in Birchgrove, Swansea for a family emergency tomorrow and Wednesday (12th & 13th February) if anyone over that way wants fobs programming (lucas only, I wont be taking pektron spares) etc, there were a couple of guys from the Swansea way who wanted this a couple of months ago.
Please PM me and we can arrange something.
Flip keys!
PostPosted: Thu Mar 07, 2013 7:41 pm
Tamworth, Staffs
I have a couple more things to add to the services I offer.
ECU security matching
I can now security match your ECU and 5as to communicate together. This is especially handy if you have a new ecu to use with your car, or you need a replacement 5as, or even you pick up an ecu and 5as that aren't from the same vehicle, I can security match them so they work together. This is available for MEMS 1.6 and 1.9. MEMS 2j is also possible if demand is high enough for this I will add it to my equipment.
Immobiliser bypass
If the immobiliser on your mg/rover is troublesome or stuck on, I can fit and program a bypass module that will make the ecu think the immobiliser is always deactivated, no more trouble.
For this, I need the ecu and the 5as from the car. This can also be fitted to unmatched sets instead of security matching them as above if complete removal is more to your requirements.
This is also for MEMS 1.6 and 1.9. As above MEMS 2J support can be added if there is demand.
As usual, these new services can be carried out in person or as a remote postal service.
Many thanks for reading.
Flip keys!
PostPosted: Thu Mar 14, 2013 10:28 am
Tamworth, Staffs
Pektron coding is now available, however this must be done in person as I have no facility to code the alarm modules off the car at present.
Prices vary depending what you need mainly because the Pektron fobs are expensive to buy, originals are rarely available and the vast majority of fobs for Pektron are now the type photographed below:
Rover 75 fobs are also available, again in person only.
These are not original fobs and do look a little different, photos available on request, you will have to have the blade cut and a suitable transponder will be needed to make the key start the car, this is purely to supply the key and program the remote fob to the cars control unit.
Freelander remote programming available by "pod" only. I send you a pod with matching fob, plug the pod in to your freelander wait 30 seconds and the fob is programmed. Return the pod to me within 5 days for a refund of the pod price.
New services being added all the time!
Flip keys!
PostPosted: Thu Mar 14, 2013 5:10 pm
Tamworth, Staffs
Special offer on security matching ecu and 5as for a limited time.
Send me a MEMS 1.6 or 1.9 ecu and 5as module and I will security match the two together allowing them to be used on the same car - £25 including return post.
If you want an extra fob supplying and programming to this at the same time, the total cost is £35 delivered!
Prices this low wont be around for long guys I'm only doing it to build interest and get the word out on my new feature.
Flip keys!
PostPosted: Tue Mar 19, 2013 12:14 pm
Tamworth, Staffs
Special offer on security matching MEMS 1.6 and 1.9 ECU's is on until April 1st 2013.
Flip keys!
PostPosted: Fri Mar 29, 2013 2:58 pm
Tamworth, Staffs
I can get a small quantity of Pektron original 3 button fobs for a limited time.
Once these are gone they are gone and I will check with my supplier when you enquire about the service.
The 3 button remote will work for your car even if you only have a 2 button fob at the moment, the third button just won't function.
Pricing on these on request and they must be done in person so you have to come to Tamworth/Nuneaton or meet me somewhere.
These won't be around for long as they are extremely rare now.
Flip keys!
 Post subject: Re: Key Fob Coding, ECU Programming and Mechanical Repairs
PostPosted: Sat Apr 13, 2013 4:35 pm
Tamworth, Staffs
I have just 2 of the original oval mg fobs left now.
Special price on ecu to 5as matching still on. (MEMS 1.6/1.9 only)
Flip keys!
PostPosted: Mon Jul 22, 2013 8:54 pm
Tamworth, Staffs
Special offer on Lucas fob coding, £18.50 including return recorded delivery if you supply your own fob, just £21 if you have a refurbished one from me!
This includes your EKA code and I can also change this for you for just £2 extra.
Can also security match MEMS 1.6 and 1.9 ECU's to your 5as/a different 5as. Just £25 including return postage recorded delivery.
I can do both of these things in person too, costs are cheaper if you come to me!
LIMITED TIME ONLY
Flip keys!
PostPosted: Fri Nov 08, 2013 11:18 pm
Tamworth, Staffs
Hi all,
Just a heads up there is a Lucas fob coding session tomorrow and Sunday in tamworth. If you want to pop along and get a new fob coded let me know and I'll tell you where to go!
£25 including the new fob and eka extraction/change if wanted.
Hope to see a couple of faces!
Flip keys!
PostPosted: Sat Nov 09, 2013 8:37 pm
Tamworth, Staffs
I am available to travel to program Lucas fobs and security match mems 1.6 / 1.9 ecus to 5as units during the next couple of weeks.
Costs will depend on where you are based and I will travel anywhere within reasonable distance of Tamworth, even better if you meet me half way or something if you are a fair distance.
Get in touch via PM for more info.
Flip keys!
PostPosted: Tue Dec 31, 2013 10:42 am
Tamworth, Staffs
New year bump :)
Flip keys!
 Post subject: Re: Key Fob Coding, ECU Security Matching & Immobiliser Bypa
PostPosted: Tue Mar 03, 2015 11:46 am
Fri Oct 25, 2013 3:12 pm
Hi, My wife has a rover 25 on an 04 plate and she lost one of her car keys with the transponder, can you give me a quote for a replacement please.Regards. Richard :)
PostPosted: Tue Aug 16, 2016 8:09 pm
Tue Aug 16, 2016 7:59 pm
was wondering if you are still active... need some help...
I am looking for a new key fob - lost one few days ago... but managed to get a key cut from code and am using key - all works fine...
was looking fob and found you. I am in Milton Keynes for few days - was wondering if you have any work this side and I can get a new fob and reprogrammed ...
please reply back with you availability and also how much are the charges...
hope to hear from you soon... thanking you
regards, ashwin
PostPosted: Wed Aug 17, 2016 1:25 pm
Tamworth, Staffs
Yes still active but nowhere near Milton Keynes unfortunately
Flip keys!
PostPosted: Fri May 12, 2017 11:05 am
Sun Jul 31, 2016 3:44 pm
Hi Booby, It's my wife's Rover Streetwise, immobilizer activated yesterday, had been playing for the last month, but I did everything, bar putting in the radio code 2 or 3 times before realising. Put in the Given Code this morning no joy, the alarm goes off just as I hit the last strike on the 4 step process! Can you help with a bypass system?
Regards Tim
PostPosted: Sat May 13, 2017 11:04 am
Tamworth, Staffs
I've sent you a PM.
Flip keys!
