It is currently Tue Feb 20, 2018 7:04 am
This topic is locked, you cannot edit posts or make further replies.  [ 186 posts ]  Go to page Previous  1, 2, 3, 4, 5, 6  Next
 Brembodge Group Buy 2
 Post subject: Re: Brembodge Group Buy 2
PostPosted: Thu Aug 26, 2010 5:05 pm
Thu Jul 30, 2009 6:59 pm
Ive got 17" Pro Race 1.2s fitted and have LOADS of clearance! :D
Edit: Just been to check and on the ZS hub I have 10mm clearance
James
PostPosted: Thu Aug 26, 2010 5:09 pm
Tue Mar 30, 2010 8:32 pm
Porto, Portugal
That´s what I wanted to read!
Thanks!
Miguel Santos - FEEDBACK here
PostPosted: Thu Aug 26, 2010 7:54 pm
Geo_coupe wrote:
We have a kit using a slightly smaller version of the 326mm disc (318mm IIRC) that will fit. It's designed primarily to fit behind a Hairpin and BRM wheel. Haven't really progressed it as there doesn't seem to be that much interest?
Would work with Pug and Renaultsport Brembo calipers too.
just noticed this, how would they compare to the 326mm disc setup braking wise? id be interested in a set for the coupe, looked at your original kits but didnt fancy risking having to get rid of the rotas!
Yeah obviously they'd have reduced maximum braking torque compared to the 326mm kit, but I very much doubt anyone (even on track) runs full pedal pressure that often as the braking force is pretty awesome....so real world I doubt you'd see a difference. And as Dan says more likely the lighter D16 will help.
I think a 16" ROTA might fit over the 326mm kit though. A 16" Superleg would do....
Ouralfilmes, glad they got to you safely mate. They might look impressive off the car - but believe me they're best on! :)
PostPosted: Thu Aug 26, 2010 7:58 pm
By far and away the roomiest wheel in that case! :twisted:
PostPosted: Thu Aug 26, 2010 8:09 pm
Porto, Portugal
Sorry but I don´t get it... Maybe my english is tricking me... You need hubs with those wheels or I did understand wrong??
PostPosted: Thu Aug 26, 2010 8:27 pm
No Ive fitted mine on a ZS wasnt sure if it makes any difference for the spacing but thinking about it now it cant! I was having a stupid moment :)
James
PostPosted: Thu Aug 26, 2010 10:04 pm
hmmm, ive taken a measurement as per method 2 from your project thread, think it would be enough to clear the 326's?
Rota Boosts 16x7 - ET?? - ZS180 282 brakes - 50.5mm
PostPosted: Thu Aug 26, 2010 10:08 pm
Porto, Portugal
OK.
PostPosted: Thu Aug 26, 2010 10:13 pm
About the same spoke-offset as the MG-Straights, which I believe NeilBaker86 fitted with a 6mm MItus spacer.
PostPosted: Fri Aug 27, 2010 5:40 am
Thu Sep 11, 2003 5:00 pm
DTEC - Mpumalanga, South Africa
Epic team dynamics PR2 clearance! :o
Miguel, pleased to see it all turned up ok. Thanks for the participation, speaks volumes for us too as traders to be trusted in the manner that you did. :)
1994 220 GSi Turbo - Gone after 7 years but never forgotten.
2001 Peugeot 306 HDi - 1999 Peugeot 306 Rallye Supercharged - 2002 TVR Cerbera 4.5 V8 LW
PostPosted: Fri Aug 27, 2010 4:12 pm
Porto, Portugal
Thank you! I am really happy with this kit! Good work! Keep the level high!
PostPosted: Sat Sep 04, 2010 3:33 pm
Fri Jul 18, 2003 9:44 pm
Shame as I have some Adendums too :(
Any other options anyone knows of?
PostPosted: Sun Sep 05, 2010 6:34 pm
Options of what?
PostPosted: Sun Sep 05, 2010 7:41 pm
Big brakes for an MG ZS that arent over £900!
PostPosted: Sun Sep 05, 2010 7:46 pm
buy ours and give up the wheels ;)
PostPosted: Mon Sep 06, 2010 6:54 am
Mitus made a kit using 316mm Bini discs and MGTF AP calipers. Search Mitus 316mm Cooper and I'm sure the project thread will come up
PostPosted: Tue Oct 19, 2010 7:01 pm
Do these work with Mitsi EVO Brembos?
PostPosted: Wed Oct 20, 2010 7:37 am
Not sure Grant. Do you have the lug spacing measurement? That would be the first qualifying point. :)
PostPosted: Mon Jan 17, 2011 4:51 pm
Rovertech Support Team
Technical Moderator
Thu May 04, 2006 12:28 pm
Glasgow
Is there part number for the solid vented discs?
Urban Explorer!
2002 MG ZR 160
PostPosted: Sat Jan 22, 2011 10:07 pm
Mon May 12, 2008 10:30 pm
Quick question. Spacing out for a 25/ZR compared to the coupe. I've been told its 3 washers. However the problem I have is if I put a washer between the bracket and the hub then theres dangerously little thread to keep it there. Remove the washer and thus remove a washer from the spacing... Ala -
Only reason I ask is, 3 washers fit as well and seem about the same!
PostPosted: Sun Jan 23, 2011 12:42 am
There should 100% never ever be a washer between the bracket and upright. Whoever told you this requires extermination....
The bracket supplied and hub should be in contact. Have you referred to the instructions supplied?
PostPosted: Sun Jan 23, 2011 3:32 pm
Nothing in paper was supplied. Glad it just wasnt me being a goon then... Got a link/PM/something?
Cheers :)
PostPosted: Sun Jan 23, 2011 3:57 pm
Technical Moderator
Glasgow
That's the way mines are set up, bracket bolted to hub, no washers other than the one on the bolts but 3 in between caliper and bracket.
Is that correct?
Urban Explorer!
2002 MG ZR 160
PostPosted: Sun Jan 23, 2011 4:04 pm
Is that correct?
Both 2 and 3 look good. So bother knows! :lol:
PostPosted: Sun Jan 23, 2011 5:36 pm
Sat Aug 20, 2005 8:23 am
Surrey
http://rover-coupe.com/rcoc/index.php?o ... structions
I don't believe Rob has updated the instructions in any way since he gave me this version.
Tom
Above all, it's a Rover!
'93 220 Coupe
'93 420GSi Sport Turbo OEM+ ;)
PostPosted: Sat Oct 15, 2011 7:43 am
Is there any plans for a second group buy on these?
PostPosted: Sat Oct 15, 2011 8:18 am
Tue Sep 27, 2011 1:24 pm
Solihull
I just ordered mine direct from rob, drop him a pm.
P.
PostPosted: Sat Oct 15, 2011 1:23 pm
Porto, Portugal
This was the 2nd Group buy.
You mean 3rd! Contact Rob. :wink:
PostPosted: Tue Oct 25, 2011 9:15 pm
ok two questions:
Whats rob's pm
how much is the full brembodge kit, on reading this initial price is just for the disc's and fixing kit. You have to pick your own calipers, brake lines, pads ect.
I am lazy, i just want a full kit
PostPosted: Wed Oct 26, 2011 9:39 am
Wed Apr 19, 2006 10:33 pm
Bathurst, Australia
ok two questions:
Whats rob's pm
I don't think Rob will sell you a full kit unless he has a set of calipers, its easier for people to find them on their own and it allows them to get them cheap if possible!
I'd budget about $550-650 for a complete set, depending on what you pay for your calipers and choice of pads.
My previous cars:
1995 Rover 220 Turbo GSI - Car Spec
1993 Rover 220 GSI - Car Spec
2002 Citroen Xsara VTS Supercharged
PostPosted: Wed Oct 26, 2011 9:45 am
Solihull
:thumbdown:
ok two questions:
Whats rob's pm
He is ttrw2, pm him buy clicking on his post a few above this one.
Sorry bud but u gonna hav to put some effort in, it's all available on fleabay if u are not about prices.
Unless someone has one for sale I doubt rob is going to outlay for everything given that some messed him around money wise with just the kit.
Or give Martin a call at reylands and take him a wad of cash with the car and he will fit them for u or spend some big bucks on a wilwood kit.
SP.
PostPosted: Fri Nov 11, 2011 9:04 am
Wed Jun 18, 2008 6:24 pm
has anybody any decent links to pads and track pads at that?
PostPosted: Fri Nov 11, 2011 10:16 am
Ferodo DS3000
Ferodo DS1.1 (Clio Cup race compound)
Camskill sell all these
PostPosted: Fri Nov 11, 2011 7:50 pm
do you have the part numbers? i am struggling to find.
Ross
PostPosted: Fri Nov 11, 2011 8:13 pm
No probs :)
DS3000:
http://www.camskill.co.uk/m49b1459s4045 ... Brake_Pads
DS1.1 (uber):
http://camskill.co.uk/m49b0s4045p53830/ ... Brake_Pads
