It is currently Wed Feb 21, 2018 10:19 am
Reply to topic  [ 29 posts ]
 Alloy Dizzy Blanking Caps
 Post subject: Alloy Dizzy Blanking Caps
PostPosted: Tue Nov 16, 2010 11:10 am
Tue Nov 04, 2003 10:43 am
Preston, Lancs.
Now that I have finished doing the manifold brackets GB, I am going to see how much interest there is in these, had a couple of people PM me for them. I am not 100% what these were for, obviously I know they were to blank the end of the cam off where the dizzy used to be attached. So the bit I am unsure of was if its for people who have lost the dizzy setup and replaced it with wasted spark?????
I am thinking around the £20 mark, maybe £22 with postage
List:-
agw_01
ravinder
rovermadman4285
Here's a few piccies
 Post subject: Re: Alloy Dizzy Blanking Caps
PostPosted: Tue Nov 16, 2010 11:25 am
1) agw_01
PostPosted: Tue Nov 16, 2010 11:29 am
How much for flat ones mate ?
PostPosted: Tue Nov 16, 2010 11:51 am
Preston, Lancs.
Not done any flat ones before. Is this to do with some people grinding the bit off the cam? I vaguely remember something about that.
PostPosted: Tue Nov 16, 2010 11:52 am
Yeah the cam sensor and rotor arm bungs pull out with a bearing puller, not to mention people on wasted spark from factory might just want a bit of bling.
PostPosted: Tue Nov 16, 2010 12:40 pm
1) agw_01
2) Ravinder :)
PostPosted: Tue Nov 16, 2010 2:54 pm
Yup basically Steb, you made that up for me - it is just a end cap to blank of the dizzy if you have converted to wasted spark but don't want to swap your cams or remove the dizzy drive from the end of the shaft.
The idea behind this was I swapped from dizzy MEMS to an Emerald K3 configured for wasted spark. I didn't want to remove the dizzy drive from the cam as I wanted to be able to swap back to the dizzy setup if I couldn't get a working map on the Emerald to drive the car to a rolling road - or if there was a problem it was simple to swap the engine loom and coil and bolt the distributer back on. So it would suit anybody else doing the same thing - or if you are running wasted spark MEMS and fitting some cams from a dizzy engine and cba to get the end bit out, or just want to retain the option of swapping cams.
Quality piece of kit needless to say - knocked up from a couple of dodgy photos with a sketch done in MS paint :sorry: :lol: - testament to the stebmiesters uber milling skillz. :wink: :thumbup:
PostPosted: Tue Nov 16, 2010 4:31 pm
I'd want one but need to wait till next month :( and would you be able to polish it :?
PostPosted: Tue Nov 16, 2010 6:37 pm
Will it fit onto a Nasp T series engine or do I need something else to be able to get hold of one of these? I'm interested but will it be expensive to change from a dizzy to a wasted spark on a 2.0 nasp engine?
Any help to a newbie would be good.
PostPosted: Tue Nov 16, 2010 11:07 pm
Preston, Lancs.
not a problem mate, and yes :wink:
Preston, Lancs.
probably one for the knowledgable guys on here that mate!
PostPosted: Tue Nov 16, 2010 11:09 pm
It's alright Ste I stuck a line on the help thread and got an honest answer. Thanks anyway
PostPosted: Tue Nov 16, 2010 11:14 pm
Preston, Lancs.
think agw_01 is gonna sort some dimensions for cam sensor bungs. I gather the flat plate for the dizzy cap would be like what i have there but flat with just them 2 holes. Would be good if somebody can measure the outside diameter of a dizzy cap, gonna modify the design slightly, then i can have the 2 holes coming out as lugs and the outer diameter a bit smaller. Any chance somebody?
Then I will do some flat plates too for people wanting them!
PostPosted: Tue Nov 16, 2010 11:16 pm
Preston, Lancs.
Not a problem mate. Your bracket went in the post today by the way ;-)
PostPosted: Tue Nov 16, 2010 11:19 pm
Cool thanks very much I'll leave you a PM and feedback when I get it thanks.
PostPosted: Tue Nov 16, 2010 11:27 pm
PostPosted: Wed Nov 17, 2010 11:42 pm
Preston, Lancs.
Picture courtesy of null_byte of his fitted
PostPosted: Wed Nov 17, 2010 11:47 pm
Al have one but need to wait till next month as my money has disappered :lol: fecking Rover tech :whistle:
PostPosted: Thu Nov 18, 2010 2:31 pm
Preston, Lancs.
Got the 3 guys on the list so for done plus one more
PostPosted: Fri Apr 15, 2011 6:12 pm
Preston, Lancs.
Got one of these left if anybody is after one!
PostPosted: Fri Apr 15, 2011 6:17 pm
Sorry to go off topic Steb but do you have any of the M series TB brackets I could get off you for my GTI?
PostPosted: Fri Apr 15, 2011 6:30 pm
Preston, Lancs.
PM'd
Sorry if anybody has tried getting intouch with me, I managed to delete all my inbox....der ;-)
PostPosted: Fri Apr 15, 2011 6:57 pm
Mon Sep 01, 2003 8:39 pm
completly missed this :(
I dont suppose you could make one up but shallower? I cut off the end of my crankshaft and dont have room for a full depth due to the location of my coil
J
"To try is the first step on the long road to failure"
mk3 200ti: 303bhp +323ftlbs viewtopic.php?t=3553
BMW 135i: 390bhp +410ftlbs
Feedback: viewtopic.php?f=44&t=83073
PostPosted: Fri Apr 15, 2011 7:04 pm
Preston, Lancs.
J
Yes I could mate, let me know in a pm how tall you need it to be.
PostPosted: Fri Apr 15, 2011 7:35 pm
Do you still want me to measure up for the cam sensor covers?
PostPosted: Sat Apr 16, 2011 12:18 pm
Preston, Lancs.
Yes please mate. That would be great, will you get some pics too
PostPosted: Wed Apr 20, 2011 6:54 pm
Cool, thanks Steb, Ill measure it up friday :)
I was thinking of fabricating something myself out of ice cream tubs and a blow torch.....
J
PostPosted: Wed Apr 20, 2011 8:53 pm
How much for flat ones ? :)
PostPosted: Sun May 01, 2011 7:48 pm
Hi Steb any update about my bracket?
