It is currently Sun Feb 18, 2018 2:03 am
Reply to topic  [ 192 posts ]  Go to page Previous  1, 2, 3, 4, 5, 6  Next
 Stainless Braided Brake Lines (the sequel)
 Post subject: Re: Stainless Braided Brake Lines (the sequel)
PostPosted: Fri Mar 25, 2011 12:36 am
What postal service did you use, Jon?
Just wondering whether it'll go through the letterbox or I ought to keep an eye out for a courier.
PostPosted: Fri Mar 25, 2011 12:52 am
Royal Mail (signed for). Has to be tracked and insured.
PostPosted: Fri Mar 25, 2011 2:24 pm
Luckily our postie always comes at lunchtime :)
All present and correct. They look to be of great quality and I'm particularly impressed with the stainless blocks they've obviously had custom-made. Great price aswell. Nice one :thumbup:
PostPosted: Fri Mar 25, 2011 7:50 pm
Glad to hear Ant :thumbup:
PostPosted: Sat Mar 26, 2011 12:47 pm
Mon Mar 12, 2007 5:48 pm
Oxfordshire
Just got mine delivered, and a very fancy bit of kit it is :yeah: :^^:
Cheers for organising the group buy Jon!
>>>Spec thread<<<
PostPosted: Sat Mar 26, 2011 1:40 pm
Thu Jul 01, 2010 4:18 am
My package arrived safely this morning. Thank you for your hard work Null_Byte.
PostPosted: Sat Mar 26, 2011 1:58 pm
Got back home this morning to find I'd missed the parcel delivery after leaving to get the missus from work. Good job my neighbour saw the postie and asked to take the parcel in for me. Brake lines look the dogs bits and I can't wait to fit them.
Thanks again
PostPosted: Sat Mar 26, 2011 2:57 pm
Sun May 18, 2008 4:34 pm
Mine arrived today, all looks excellent. Thanks a mill for the effort needed to do this, especially to Ant for scrabbling under a scrapper to get the sample.
Tim
PostPosted: Sat Mar 26, 2011 7:12 pm
Sat Aug 20, 2005 8:23 am
Surrey
Looks like Royal Fail have let me down; no package here :(
Tom
Above all, it's a Rover!
'93 220 Coupe
'93 420GSi Sport Turbo OEM+ ;)
PostPosted: Wed Mar 30, 2011 12:36 am
well fitted mine in the end.
had a few issues
1:they came with two fixing points on the hoses .( the black plastic bit) so had to cut the extras off.
2: the ends didn't fit through the hole on the chassis so had to drill the chassis mounting hole out( where hose turns to copper).
3: dunno if this is the same on all rear disc coupes but the rears could of done with being slightly longer and the hose is at a very tight bend when it mounts to the caliper . as the std rubbers are longer and bend more smoothly if you know what i mean .
i very nearly didn't fit the rears due to this and was gunna put the old rubber ones back on. ill just have to keep a eye on it .
i also put those stainless banjo bolts straight in the bin and kept the old ones :wink:
apart from that my brakes are now really really .... spongy lol . more bleeding is required i think lol
PostPosted: Wed Mar 30, 2011 7:33 am
PostPosted: Wed Mar 30, 2011 9:13 am
Surrey
You did fit the hoses on the correct end of the car didn't you Martin? The hoses with two fixing points are for the rear (don't ask exactly where they fit because I can't remember) and the single fixing point hoses are for the front.
Tom
'93 220 Coupe
PostPosted: Wed Mar 30, 2011 9:51 am
Thu Sep 11, 2003 5:00 pm
DTEC - Mpumalanga, South Africa
This. Was my immediate thought when you said two fixing points, you can mix them up.
1994 220 GSi Turbo - Gone after 7 years but never forgotten.
2001 Peugeot 306 HDi - 1999 Peugeot 306 Rallye Supercharged - 2002 TVR Cerbera 4.5 V8 LW
PostPosted: Wed Mar 30, 2011 10:21 am
I'm just going to cover myself at this point and say, the 1st isn't till the day after tomorrow right? :lol:
As said above, check you have these the right way around. The rear hoses have two brackets, the fronts have one.
If you have any problems please ask before doing anything! DON'T cut or alter the hoses as it will then be impossible to return them if there is a problem!
You may have to clean out the hole, but you shouldn't need to drill it at all, this will expose bare metal and cause your bracket to rust. Both HEL and Goodridge use similar fixings on the body end, a large nut replaces the flat sided locating lug. The should just push through and then retain with your spring clip. If your bracket is badly corroded then you may need to address this before fitting the hoses by cleaning it out and rust treating it.
Martin, I hate to say it, but it really does sound like you have mixed up the fronts and backs, the backs are 50mm longer than the fronts and have an angled banjo, so if you are using the fronts on the back this would explain why they are too short and don't fit.
I echo the above, why? They are one of the best bits of the kit - I can't see any reason to keep the old ones in preference. Remember to remove the old steel washers from the calliper (they tend to stick to it) before fitting them though.
In other news, Tom now has the brembodge custom lines for testing and once he has given it his seal of approval I will get the rest of the order made up and shipped out swiftly to you all!
PostPosted: Wed Mar 30, 2011 10:40 am
Surrey
I'll be doing the trial fit on Saturday. Initial inspection of the hoses and comparison to my current Goodridges give me no reason to suspect there will be any fitment issues whatsoever, but I'll give them the all clear once fitted.
Tom
'93 220 Coupe
PostPosted: Wed Mar 30, 2011 3:35 pm
Tue Jul 27, 2004 1:40 pm
Bagdad
As above Mart it does sound like you stuck the fronts on the rears, again you can always ask first if in doubt..
H
crap coupe owner.... H1 BHX
Own a coupe click here
http://www.rover-coupe.co.uk/
PostPosted: Wed Mar 30, 2011 5:59 pm
ah i see . would of thought fronts would of been longer lol .
you know me i just hodge it and bodge it wheres my hammers!
never had this issue with my trusty drums! :P
and yeah prob was full of rust it is a rover .
and cus ive known of calipers to split due to different expansion rates etc
PostPosted: Wed Mar 30, 2011 6:39 pm
Sun May 06, 2007 9:54 pm
Staffs
This brake line dude is slooooow :annoy:
All good things come to those who wait :lol:
***LOTS OF 600 BITS FOR SALE***LOTS OF BITS FOR SALE***LOTS OF OTHER BITS FOR SALE***
PostPosted: Thu Mar 31, 2011 12:30 pm
Sat Jun 13, 2009 5:56 pm
Bakel, the Netherlands.
Received today :)
Rover 214sli 1995
Rover 220 coupé 1995
VW Polo 1.9D 1999
Rover BRM 2000
Honda VFR 2002
vfr16v wrote:
sold to me? :whistle:
Fukc me your buying everything :o have you won the lottery :?
PostPosted: Sat Apr 02, 2011 5:25 pm
Surrey
I completed the trial fit of the Brembodge hoses this morning and thus far everything looks good. Quality of the hoses was spot on and I experienced none of the fitment problems described by Martin, however I only fitted the front hoses today.
I took a couple of photos of my mornings work...
Old banjo fitment
OE Rover banjo and Peugeot/Brembodge compression fitment side-by-side for comparison
New hose installed
There are no clearance issues on full lock with the hoses being set further out from the caliper compared to the OE banjo fitment
Couple of additional shots following installation
Just as an aside (and mainly for martin's benefit ;) ) here are a couple of shots comparing the front and rear hoses. The hoses shown are my old Goodridge lines, however the same differences apply equally to the HEL lines.
Front hose (with the single mounting lug) is shown at the top. The rear hose with twin mounting lugs is the one at the bottom. Note the length difference between front and rear.
The banjo fittings are also different. The rear hose, shown on the left here, has an angle on the banjo fitment whereas the fronts are straight.
Tom
'93 220 Coupe
PostPosted: Sat Apr 02, 2011 5:32 pm
Nice one Tom. I shall give them the greenlight to go ahead with the last bits off the order and we can get things moving.
I'll email them tonight and then phone them Monday to confirm everything...just in case lol.
PostPosted: Mon Apr 04, 2011 10:24 am
Emailed and phoned.
Oustanding kits are:
mike88
Jase
1994 BRG Coupe
220Lee
Adam-MGTF
BazR
Confirmed all orders with them, so now should be quite simple (I hope)
PostPosted: Mon Apr 04, 2011 10:59 am
ha i wasnt being a fool . i did fit them round the right way . theres no bend on the banjo thought? ill get pics up to show you
im not complaining . and i have re bleed and brakes are hard as nails now!
PostPosted: Mon Apr 04, 2011 11:02 am
Thu Feb 14, 2008 6:06 pm
Suffolk
Is this all finished now or can you still add any orders??
PostPosted: Mon Apr 04, 2011 12:17 pm
Staffs
Null_Byte wrote:
Emailed and phoned.
mike88
Jase
1994 BRG Coupe
220Lee
Adam-MGTF
BazR
And mine :?
PostPosted: Mon Apr 04, 2011 12:24 pm
If you put the ones with double clips on the front, and then cut off one of the clips they are almost certainly round the wrong way martin, the banjo angle shouldn't be critical (although should still be there), but the rear hoses will be longer.
98Ti wrote:
And mine :?
Got your kit sat here Matt, but no clips, they are coming with the rest of it so I'll just pop them in the same jiffy bag and you're sorted. :thumbup:
PostPosted: Mon Apr 04, 2011 7:57 pm
Sun Oct 24, 2010 9:49 pm
Null_Byte wrote:
Emailed and phoned.
mike88
Jase
1994 BRG Coupe
220Lee
Adam-MGTF
BazR
4 more names! lol and it's my turn :D can't wait!
PostPosted: Wed Apr 06, 2011 1:39 pm
Good news everybody....
Well, sort of. :lol:
The kits arrived today, but they are slightly different to the ones Tom tested. :facepalm: I was about to bang my head against the wall but I've tested them and I think they will be fine.
The difference is the plastic bracket used to locate the line - the previous kit had a single hole bracket, these have a double hole - however when you look at it the bracket still lines up and I've checked rear hose against a spare rear trailing arms I have here and it looked good.
i have no idea why they have made the change, but rather than mess people around any longer I have sent out all the kits. If there are any problems, as I've said before, contact me first. I'm pretty confident they will be OK though.
The only other problem is the post office is shut until Monday, so they are in the post, but probably won't get there till next week now, but I thought it was best to get them sent off either way.
Once again, I'm sorry things have not gone as smooth as last time, but I hope you will all be happy with the kits. :thumbup:
Kits posted today are:
mike88
Jase
1994 BRG Coupe
220Lee
Adam-MGTF
98Ti
PostPosted: Wed Apr 06, 2011 2:28 pm
Hooray!
PostPosted: Wed Apr 06, 2011 3:24 pm
Mon Sep 01, 2003 8:39 pm
yay! thanks Jon.
funny thing is my front brakes are fooked now so im no longer in such a rush to do the rears
fecking cars. I hate them.
:crash:
J
"To try is the first step on the long road to failure"
mk3 200ti: 303bhp +323ftlbs viewtopic.php?t=3553
BMW 135i: 390bhp +410ftlbs
Feedback: viewtopic.php?f=44&t=83073
PostPosted: Wed Apr 06, 2011 3:57 pm
Staffs
Things are looking up :D
PostPosted: Fri Apr 08, 2011 7:54 pm
Got mine Jon, thanks :)
Prob be fitting them next weekend now tho as have to completly rebuild/renew my front brakes this weekend. :annoy:
J
PostPosted: Sat Apr 09, 2011 4:54 pm
:D :D :D
Mine arrived too
:D :D :D
Well worth the wait, many thanks for organising the group buy.
PostPosted: Sat Apr 09, 2011 5:36 pm
Got mine this morning.
Thanks for the effort you put into this Jon.
Mike
PostPosted: Sat Apr 09, 2011 10:09 pm
Glad it all got there in the end! :D
